    I'd probably just look at teh drivers, scrap whatever control system is there and do a retrofit, cant be too difficult. The boards seem well marked, probably a good setup for an Acorn or Mach retrofit.
    Thank you Chaz, I have another smaller machine with stepper control box too. I run Vcarve and Mach3 - would it just be a case of I could use that to run this machine and bypass the DSP ?
    Sent from my SM-G965F using Tapatalk
    PM sent
    Phill
  3. The Following User Says Thank You to phill05 For This Useful Post:
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 3 Weeks Ago Has a total post count of 1,657. Received thanks 115 times, giving thanks to others 71 times.
    PM sent
    Phill
    Offer to fix it?
  5. The Following User Says Thank You to Chaz For This Useful Post:
  6. #4
    Offer to fix it?
    Hi Chaz,
    No only supplied the DSP manual and some other files.
    We changed from DSP to Mach 3 a few years ago so were no longer needed.
    I am currently trying Acorn, after a problem setting it up I now have it test running 4 axis for a router / mill and also have the lathe side running it will be made into a portable unit to take to other machines when complete.
    Phill
  7. #5
    Chaz's Avatar
    Sorry, what is DSP in this case?
  8. #6
    The DSP is the hand held controller to power this machine.
  9. #7
    Chaz's Avatar
    Ah ok thanks.
  10. #8
    Hey Phil thanks for all your help on this, actually feel like things are progressing. Don't mean to sound a nause as I'm sure your going to be busy with your own work.
    Do you have any suggestion for breakout board to Mach3 with these drivers ?
  1. NEW MEMBER: Production grade CNC router Vs Homebuilt CNC router advice
    By SweetAs in forum New Member Introductions
    Last Post: 16-02-2019, 12:06 PM
  2. Replies: 4
  3. what router can i use with openbuild ox gantry router?
    By davejavu123 in forum OpenBuilds OX CNC Machine
    Last Post: 13-08-2015, 01:40 PM
  4. eBay: CNC Router - EXELCNC HD1013 - Heavy Duty CNC Router
    By Deuce_Coupe in forum Items On eBay UK
    Last Post: 16-07-2014, 11:46 AM
