20-09-2018 #1
I had to move my machine which was epic, including removing most of the wiring. During the move I lost part of the power connector for the spindle so I couldn't lock the wiring into the spindle to ensure no movement.
After much searching I believe I have sourced the correct replacement
GX20 4 pin female
The cheap direct from China source
https://www.aliexpress.com/item/1set...ceBeautifyAB=0
UK source
https://www.ebay.co.uk/itm/GX20-Avia...72.m2749.l2649
EU source
http://cnc-plus.de/en/CNC-Electronic...3A---40V-.html
Hopefully someone else will find this information usefulLast edited by Desertboy; 20-09-2018 at 12:06 PM.
22-09-2018 #2
I thought they were GX16 which are a bit smaller in diameter. Just check they will fit through the hole in the end cap.
The Following User Says Thank You to routercnc For This Useful Post:
22-09-2018 #3http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
04-10-2018 #4http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
Help! Need 3040 CNC (JP-1482) spindle/power board replacement??
By JBSD in forum Chinese MachinesReplies: 1Last Post: 24-01-2018, 07:24 PM -
What power of spindle for cutting 4mm phenolic with 3mm cutter?
By Nicholas Collier in forum Spindles & Drive MotorsReplies: 4Last Post: 27-03-2017, 07:26 PM -
Which circular connector for spindle
By ROBCNCAU in forum Spindles & Drive MotorsReplies: 7Last Post: 19-06-2016, 09:20 AM -
TB6560 controller Runs spindle on power up When Mach3 plunges spindle stops
By RoyT in forum Spindles & Drive MotorsReplies: 5Last Post: 29-09-2014, 02:42 PM -
Spindle water hose connector
By cncJim in forum Marketplace DiscussionReplies: 6Last Post: 20-02-2014, 11:22 AM
