    I am very interested if you guys find out we can use settings to boost low rpm torque without burning up the motor.
    Do we have a reason to think HY put unreasonable reservations in the settings ... over protective measures so to speak?
    I would like low rpm performance too.
    Grtz Bert.
    Neale - Thank you, very interesting thread. I hope you will post your results please. I have been down this road on a similar router with moderate success using carbide+coated cutters. I did find a definite advantage adding just a smear of the blue EP metal working lubricant, with a finger, to the projected toolpath. So minimal mess and it also kept some of the chips on the metal surface.
    Your VFD setting results would be particularly welcome as have to admit a bit windy of touching my working settings.
    Lives in Plymouth, United Kingdom. Last Activity: 4 Weeks Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    I'm afraid, guys, that I'm probably not going to be experimenting with VFD settings, at least not for my current project.
    I wasn't sure that there was a lack of torque - pushing a 2.5mm cutter, even through steel, isn't going to need very much - but rather a problem with speed control at low speeds. Watching the cut in progress, I suddenly remembered what the effect reminded me of. I was seeing what was almost a tiny pause, a slight release of the cutter, and associated squealing and poor finish. Just like turning when you take a shallow cut on a metal prone to work-hardening. So I wound up the feed speed a little which helped significantly. I then ran out of the cold-rolled bright mild steel I had been using and swapped to hot-rolled black steel. Which cut much better and without the vibration/"pausing" effect - so I think I probably found the answer. I suspect that the bright mild knocked the edge of my cutter, though, as it didn't last much longer even in the softer metal. I'll ramp up DOC next time and see how it goes.
  1. Irregular Spindle Speed
    By HipoPapi in forum Spindles & Drive Motors
    Last Post: 07-07-2016, 06:07 PM
  2. So Nearly there - Mach3 and VFD Spindle Speed.
    By davegrennan in forum Artsoft Mach (3 & 4)
    Last Post: 11-04-2015, 12:30 AM
  3. Spindle Speed Control
    By cncJim in forum Spindles & Drive Motors
    Last Post: 18-06-2013, 07:53 PM
  4. Spindle Speed Measurement
    By clockmaker in forum Spindles & Drive Motors
    Last Post: 04-12-2010, 11:38 PM
  5. High speed spindle
    By leadinglights in forum Tool & Tooling Technology
    Last Post: 27-04-2010, 09:23 PM
