Thread: 4th axis and fusion 360 problem
	22-09-2018 #1
Having real problems with my 4th axis . Can any one help. IV just installed it and made a small model in fusion this is my first time using the 4th . When I run I code it runs ok for the most but the the 4th (A) slows down to almost a stop . It crawls along at about 1mm a minute . Then after it gets to where it's going all speeds up again. It does this 2 or 3 times in the operation . IV run it 5-6 times and it happens at the same place every time. I'm scratching my head not knowing if it's the post processing or fusion or my new 4th axis or my stepper. iv added some videoAny help would be cool
	22-09-2018 #2
stops at 490 line every time here
	22-09-2018 #3
What speeds and feeds have you selected in the F360 CAM settings tab? In your screen shot, the machine speed drops right down at the line marked, where there is a significant move in A.
	22-09-2018 #4
	22-09-2018 #5
iv changed nothing from this
	22-09-2018 #6
I'm probably talking the proverbial... but 490?, your Mach3 installation is licensed?
	22-09-2018 #7
Yes it's I'm running some more code and it's still doing the same thing but at line 234
	22-09-2018 #8
been trying to get this working for over a week now . almost giving up on it
	22-09-2018 #9
Both examples that you show freeze with very slow feed rates (F554/F373) compared to the preceeding gcode - can you confirm that these lines do indeed have the lowest feed rates upto that point in the gcode?
If so, add a zero (x10) and try an air-cut, see if the behaviour is the same
	22-09-2018 #10
this is some more code im running and it is doing the same thing what do you think
X-16.223 A24.234 F8759.5091
X-16.233 A23.903 F20792.2569
X-16.242 A23.465 F17076.7648
X-16.247 A23.027 F18351.0809
X-16.248 A-2.375 F346.9053 <------- stops at this line every time and runs really really slow
X-16.24 A-3.806 F5889.3929
X-16.22 A-5.243 F5463.8838
X-16.187 A-6.724 F4964.8767
X-16.139 A-8.234 F4565.2459
X-16.077 A-9.76 F4244.1414Last edited by amxen; 22-09-2018 at 08:37 PM.
Y axis problem
By Kev2960 in forum Chinese MachinesReplies: 32Last Post: 15-09-2017, 04:38 PM -
Z axis problem
By Kev2960 in forum Chinese MachinesReplies: 12Last Post: 19-02-2017, 10:09 PM -
Help with Problem X axis Stepper Please
By howser37 in forum Gantry/Router Machines & BuildingReplies: 53Last Post: 09-02-2017, 06:31 PM -
Problem with my Z axis
By mikem in forum Stepper & Servo MotorsReplies: 4Last Post: 03-11-2015, 11:52 PM -
z axis problem on rye ma 1500 with a bosch cc100
By rickybabe in forum Rye CNC RoutersReplies: 3Last Post: 28-04-2010, 09:04 AM
