    Chaz's Avatar
    Quote Originally Posted by AdrianW View Post
    I've just bought a Harrison M250 that has factory-fitted CNC system, but the control system didn't come with it. As a result I essentially have a lathe fitted with stepper motors, adjustable stop switches and an encoder on the spindle. I know enough about electronics to sort out drivers for the motors etc. but being new to CNC I really don't know where to start with the control system - I gather that Mach3 is a good option for the SW but ideally I want a controller that will use the features of stop switches and the spindle encoder - it would be easy to use just the two motors but it wouldn't be long before I wanted to do something like thread cutting, and as the lathe doesn't have a full set of change wheels I might as well put the money into improving the CNC features.
    So, the question is whether anyone can recommend a control system that would work with Mach3 and interface to the stop switches and spindle encoder.
    BTW FP on MYCNC, so Hi to all!
    Ive just installed Centroid Acorn on a Harrison M300. I'd never look at Mach 3 again, not the same league.
  2. The Following User Says Thank You to Chaz For This Useful Post:
  3. #2
    Lives in East Lothian, United Kingdom. Last Activity: 5 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    It all depends on how much functionality you want to add.
    If you're happy with on screen jogging, and no fancy tool changer, Centroid Acorn will achieve that. If you want to add an MPG for jogging, then the Acorn is out (it only supports a single encoder input, and has limited inputs and outputs).
    If you want more functionality, then a Dynomotion KFlop will give it, but it's not as easy a system to implement.
    Mach is still an option, but being realistic for a lathe, you'd either have to ditch the spindle encoder and go single slot, or buy a motion controller that does support encoder threading with Mach. IIRC only the full fat CS-labs controllers with an additional MPG module support it, or a KFlop can work with encoders and Mach3. Some of the Galil controllers probably also support it, but I'm not sure on how well they work with Mach.
    I think the CNC Drive UC controllers can support multi-slot threading, but not a full encoder. They also have their own control software, UCCNC, but I'm not sure how much support it has for lathes.
    Out with that, you're into a bunch of controllers that can only support single slot threading, or controllers with no threading support. The best guesses I've seen for the number of turn/lathes users in the hobbyist/retrofit market, have all been less than 10%, so there just isn't the same level of support compared with mills/routers.
    LinuxCNC with a Mesa card is another option.
    Off course, the other option is a standalone controller.
    It all comes down to how much money you're willing to spend, and what functionality you'd like.
  4. The Following User Says Thank You to m_c For This Useful Post:
  5. #3
    Chaz's Avatar
    On the iPad so quick response from me. Centroid now has an integrated MPG option, 240 usd or so, well regarded. You can also now use something like a shuttle controller as a supported interface.
  6. The Following User Says Thank You to Chaz For This Useful Post:
  7. #4
    I did have a look last night after I posted to see what they've been up to, and noticed that, but $240 for a XHC pendant you can get on Aliexpress for $99 does seem a bit steep.
    Cheap and cheerful option for KMotionCNC is a gamepad. Quite a few people use wireless Xbox controllers.
  8. #5
    Chaz's Avatar
    Agreed, there is a markup however they have done all the integration bits to make it work reliably. Ive seen a gamepad being used for the Acorn system too, there was / is a Harrison 300 lathe on ebay with Acorn running with an xbox type controller.
    Also, they are about to launch a 16 in / 16 out add on board, lack of inputs and outputs has not helped.
  9. #6
    The potential problem with that, is it's a hollow shaft encoder, which aren't as easy to mount/drive.
    Something like this would also work - https://www.ebay.co.uk/itm/1-pc-New-...oAAOSwImRYIVLB
    But that's from China.
    It really depends on what the existing setup is, whether it can be adapted, or if a complete new setup is needed. A photo of the existing setup would be good.
    A lathe using a gamepad controller fills me with dread for some reason!
    Probably because I know how much a damage a crash on a lathe can do, where as at least on a router/mill, the biggest damage is likely to be a broken cutter.
    I noticed the IO expansion as well. It's interesting they're having to rely on ethernet though. I would of thought using the i2c or UART ports on the BeagleBone would of been an easier option.
  10. #7
    Chaz's Avatar
    Agreed, he often sells the shaft versions too. I bought a hollow one and struggled but had to be done.
  11. #8
    Here's a photo of what's on there now - it's an HP HEDS-5310 - I'm pretty sure this range doesn't go over 512 counts/rev so it's well under the minimum. As you can see space it tight - I'll probably have to make a new bearing assembly to allow anything bigger to fit in. For clarity, the encoder is the smaller black housing up against the gearbox. The larger black cylinder next to the pulley is a bearing housing that's bolted to the mounting bracket.
Name:	Untitled picture.png
  12. #9
    I forgot to mention, British Encoder (www.encoder.co.uk) are a UK manufacturer/supplier, and are helpful. Not the cheapest option, but a direct drop in replacement for my Denford Cyclone was about £200.
    Zapp Automation also supply some encoders, and Gary (who occasionally frequents here) is very helpful.
    Other option is US Digital, where you can pick disc/reader head options to suit your application.
  13. #10
    Thanks for the recommendation - the Centroid forum seems pretty good so it looks like I'm going to be looking for a decent spindle encoder (it's got an optical HP one that's way under the minimum spec.) and also a VFD that's compatible with the Acorn - if you have any suggestions for one that's not silly money I'd be very grateful. I'm liking the idea that I might be able to do rigid tapping!
  1. My CNC converted Harrison M250
    By M250cnc in forum Conversion Build Logs
    Last Post: 14-01-2022, 09:20 PM
  2. FOR SALE: Complete CNC plasma control system with THC from CandCNC.com
    By adscnc in forum Items For Sale
    Last Post: 11-01-2022, 01:25 AM
  3. RFQ: Semi automatic welding system Linear beam control system
    By richway in forum Projects, Jobs & Requests
    Last Post: 24-01-2017, 08:54 PM
  4. drive control system
    By oadamo in forum General Electronics
    Last Post: 22-05-2011, 07:30 PM
  5. Harrison M250
    By Arthur Kingdon in forum Milling Machines, Builds & Conversions
    Last Post: 14-06-2010, 08:36 PM
