27-09-2018 #9
The potential problem with that, is it's a hollow shaft encoder, which aren't as easy to mount/drive.
Something like this would also work - https://www.ebay.co.uk/itm/1-pc-New-...oAAOSwImRYIVLB
But that's from China.
It really depends on what the existing setup is, whether it can be adapted, or if a complete new setup is needed. A photo of the existing setup would be good.
A lathe using a gamepad controller fills me with dread for some reason!
Probably because I know how much a damage a crash on a lathe can do, where as at least on a router/mill, the biggest damage is likely to be a broken cutter.
I noticed the IO expansion as well. It's interesting they're having to rely on ethernet though. I would of thought using the i2c or UART ports on the BeagleBone would of been an easier option.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
My CNC converted Harrison M250
By M250cnc in forum Conversion Build LogsReplies: 6Last Post: 14-01-2022, 09:20 PM -
FOR SALE: Complete CNC plasma control system with THC from CandCNC.com
By adscnc in forum Items For SaleReplies: 2Last Post: 11-01-2022, 01:25 AM -
RFQ: Semi automatic welding system Linear beam control system
By richway in forum Projects, Jobs & RequestsReplies: 0Last Post: 24-01-2017, 08:54 PM -
drive control system
By oadamo in forum General ElectronicsReplies: 1Last Post: 22-05-2011, 07:30 PM -
Harrison M250
By Arthur Kingdon in forum Milling Machines, Builds & ConversionsReplies: 24Last Post: 14-06-2010, 08:36 PM
