10-10-2018 #1
I've just been getting a quote from Fred at BST for some custom length ballscrews, in his last email he mentioned the option of superior quality end bearings, which apparently have P5 Angular contact ball bearings in the BF (floating) end. They're about $24 per screw more expensive, just wondering if anyone had any experience of them please and whether they're worth the extra dosh??.
11-10-2018 #2
I took the better option and they are well worth the money. Wouldn't buy anything else and Fred is very helpful
Simon
Sent from my SM-G925F using Tapatalk
11-10-2018 #3
Yes i have them too.
Make sure Fred sends you bearing sealed at the blocks or self sealing bearings.
Please check my buildlog there is pictures of what went wrong in my order.
I agree Fred is the best... he solved the seal issue for me once he understood the problem.
I have no experience with lesser quality bearings but yes i like the superiors.
Grtz Bert.
11-10-2018 #4
Just visit a decent Industrial Bearing Supplier and tell them what you need, generally you get better products at a fraction of the online prices!
15-10-2018 #5
16-10-2018 #6
So am I right in thinking that this kind of setup is essentially working like having fixed bearings at both ends? - there's an obvious advantage in reducing "whipping" at high speeds that way. Would some preload help even further, or does "just-and-so tight" sort most of it?
16-10-2018 #7
https://www.linearmotiontips.com/cho...-applications/
Be careful of thermal expansion on Fixed/Fixed long leadscrews.
Regards
Simon
16-10-2018 #8
Thanks for the link. It sounds like Fred is offering the "double floating" variety of bearing then.
Another thing that struck me today was that (if you have space for them) having 2 "floating bearings" spaced a bit apart ought to resist whipping, whilst not giving any problems due to thermal expansion. The thermal expansion thing I guess will only be a major problem on machines made from dissimilar metals anyway e.g. aluminium frame with steel ballscrews. I was quite suprised how much it could be when I did the sums for my design, about 0.5mm for a 1700mm long machine with a 20 degree C change.Last edited by Voicecoil; 18-10-2018 at 09:04 PM.
BUILD LOG: "Henge", 3 Axis Cnc, Fixed Gantry, Moving Table
By Greeny in forum DIY Router Build LogsReplies: 15Last Post: 20-03-2017, 08:43 PM -
"Hacking" and "Modding"
By magicniner in forum General DiscussionReplies: 15Last Post: 07-01-2015, 08:59 PM -
CNC machine "Spanish" model . Advice and opinions needed!
By shapebusters in forum Machine DiscussionReplies: 17Last Post: 12-03-2014, 06:21 AM -
Interesting Article "Makers unite - the revolution will be home-made"
By Fivetide in forum General DiscussionReplies: 4Last Post: 28-09-2012, 12:06 PM -
"Racks" VS "ball screw"
By C.AlveSilva in forum Linear & Rotary MotionReplies: 1Last Post: 17-04-2012, 11:53 PM
