10-10-2018 #1
So, I'd worked out roughly what sort of machine I need to build and had done some basic sums using both the excellent spreadsheet @routercnc provided and some other calculations and was just about to order in some great big lumps of profile. It seemed clear that for the gantry, torsion (twisting moment) was going to be the dominant source of cutting tool movement, kind of obvious when the tool tip is down near the bed as the length of the Z axis acts a a lever. I'd assumed that the performance of a piece of rectangular box section and a profile of roughly the same dimensions would be fairly similar as the moments of area (Ix, Iy) for normal flexing do seem to roughly match up weight for weight, so had happily gone ahead assuming I could plug values into the spreadsheet and get meaningful tool deflection figures for profiles.
THEN, I happened to come across the Item24 website, those guys are possibly the Nirvana of aluminium profiles, they have something to solve pretty well every problem ina very efficient german way. And, uniquely they state the torsion constant (J) for most of their profiles (basically how hard it is to twist it). AND the figures are very different (i.e. a LOT smaller) than the equivalent sized rectangular tube. Thinking about it now, it kind of makes sense, as playing around with anti-roll bars taught me that to get a stiff tube, you need to get as much thick, continuous metal as far away from the centre of rotation as possible. Whilst all the slots might add or certainly won't detract much from flexural stiffness, profiles only have a continuous "tube" at the bottom of the slots, a fair way in from the outer periphery, and the bits at each corner (where the stress is concentrated in a rectangular tube) do practically nothing to add torsional strength.
Anyway, here's a little comparative table of profiles and rectangular tubes: the profiles are all Item/KJN/Motedis patterns (they all are the same sort of shape and have similar Ix,Iy within a few %), stated prices are from whoever was cheapest when I looked. Prices for box are from my local stockholder, there's obviously money to be saved as well as gaining torsional stiffness
Profile Moment of Area x Moment of area y Torsion constant weight cost per metre Item 80 x 120 lite 201 422 165 8Kg £55 Item 80 x 120 273 575 261 11Kg £81 Item 80 x 160 Lite 270 919 250 11Kg £77 Item 80 x 160 362 1232 397 13.5Kg £101 Item 120 x 120 799 799 578 12.4Kg £158 80x120x6.75 tube 251 482 498 6.9Kg £48 2"x6"x1/4" tube 104 642 287 6.7Kg £43 3"x6"x3/8" tube 352 1152 853 10.9Kg £58 70x80x4.4 tube 191 860 493 5.9Kg £39 80x200x6mm tube 360 1570 922 8.8Kg £56 100x200x5mm tube 515 1522 1183 7.8Kg £56
You can probably guess what I'm going to be using for my gantryLast edited by Voicecoil; 11-10-2018 at 04:47 PM. Reason: This forum software can't handle tabs!
11-10-2018 #2
11-10-2018 #3
11-10-2018 #4
Hmm, you assumed a profile with a trench to near centre had any torsional strength?
LOL!You think that's too expensive? You're not a Model Engineer are you? :D
12-10-2018 #5
12-10-2018 #6
Hi Voicecoil,
I think you did a very good job explaining how the most 8040 t sloted and alike style alu profiles have the less disireable shape for torsion resistance.
And yes round tube is best shape to resist torsion.
I agree the steel/epoxy route is harder to do.
Wish i had someone that could have milled / grind flat my bed / gantry...
Epoxy was a gamble that luckily worked out great for me.
Just buy the biggest heaviest best shaped profile that fits your design / needs / budget.
Rigidity rules.
Grtz Bert.
14-10-2018 #7
Glad someone is still finding the spreadsheet helpful !
Yes Ixx and Iyy values relate to relative bending performance in the up/down or fore/aft direction (independent of material, just relating to the geometry).
Whilst this is important for a gantry what will dominate the requirement is the torsional stiffness as you point out. My spreadsheet allows you to calculate this for simple shapes but for complex shapes like profiles you need to use FEA which is probably what that company used.
As you and others noted continuous shapes with material away from the centre are best, and many quote a circle as the stiffest shape for torsion but actually there is a stiffer shape. A 50mm diameter square box section will twist less than a 50mm round tube. The extra bits in the corners of the box which are further away from the centre resist the torsion even more so it wins out. This is good news for gantries which can be square or rectangular which are more practical and be better for torsion plus way better for bending than the tube.
Also popular is adding 2 rectangles into an L shape and getting more stiffness with a very practical shape.Last edited by routercnc; 14-10-2018 at 01:53 PM.
The Following 2 Users Say Thank You to routercnc For This Useful Post:
A good supplier in UK for Aluminium profiles
By suspension in forum Marketplace DiscussionReplies: 0Last Post: 07-12-2017, 02:46 PM -
FOR SALE: for sale or trade, lots of aluminium modular sections and a few slides and rams
By nobby in forum Items For SaleReplies: 3Last Post: 25-06-2013, 08:30 AM -
Musings on building a workshop and a new machine...
By irving2008 in forum Workshop & EquipmentReplies: 102Last Post: 19-10-2012, 06:44 AM -
Straight sections of box steel
By gavztheouch in forum Metalwork DiscussionReplies: 2Last Post: 03-01-2012, 02:37 PM -
Aluminium Profiles
By wizer in forum General DiscussionReplies: 10Last Post: 10-03-2010, 11:41 AM
: however at the moment I'm much better set up for machining aluminium than steel. And part of the reason for the post was to highlight the low torsional performance of normal slotted profiles.
