    Hi Chaz
    Yes great cad/cam software quite easy to use also my main design software is Aspire V Carve. But at the present moment I need to upgrade my controller and I am looking for an appropriate controller thats reliable and has a proprietary software program any ideas.
    Chaz's Avatar
    Quote Originally Posted by joss01 View Post
    Hi Chaz
    Personally Id just install Centroid Acorn. Its stable, runs well and is slowly gathering pace as a viable product. Centroid is a known entity, this is their entry into the DIY market. Ive got one on my lathe.
    Yes I will google the product and do some research thanks
    Chaz's Avatar
    Lives in East Lothian, United Kingdom. Last Activity: 1 Hour Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Correct me if I'm wrong, but the stand out thing for me, is you've learnt to use the existing controller even though it's in Polish and it's working well, but you still want to upgrade it?
    Having had a look at the PIKO site, it looks like a good package, so as along as you've figured out how to use it, I don't think I'd be in much rush to swap it to something else.
    Yes I had the same feedback from a colleague but I am having teething problems with setting up certain parameters because of the wording. I have used translation software and blindly adjusted the cnc with some positive results but I still need to iron out some gremlins which I am finding some what of a challenging.
    He needs to know what type of signal the servos/steppers work with, then the controller. I have not been here a couple of months but from when the ACORN is the recommended controller for retrofit? I hear for first time they have a cheap DIY controller. I agree that the original controller looks very good, so i dont see the point.
    Does the machine has more complicated functions like tool changing, 4rth axis, or is just 3 axis router for stone engraving?
    Hi Boyan just one thing the shoe works and fits perfectly and looks great I earthed the tubing as you said and had no problem. The cnc is a 3 axis with basic functions. I did read up on the Acorn and the reviews did not look good. I am looking for a good quality controller to upgrade the PIKO cost is not the issue more quality and performance.
  9. The Following User Says Thank You to joss01 For This Useful Post:
  10. #9
    Great to hear! Thanks!
    Now your machine is with the Ethernet controller? I assume it's quite frustrating working with a controller in Polish :-) . How do you square the long axis now? Via the controller?
    What exactly would you like to be able to do with the new controller, apart from the basic stuff?
    I will greatly encourage you if you change to change to a dedicated controller, without PC, Windows, Mach3 and other similar crap. After i build my machine and changing a couple of controllers from Galil to Pokeys, i was extremely disappointed with all of them. Needless to say i hate Mach3 / 4 from my heart /even i paid for their bloody license at the time/, always bugs, don't follow the perfect sequence/that you have to find/ and all will crash and so on. From the moment ii put the dedicated Chinese controller, its already 2 years that i have not had even a glitch
  1. Replies: 0
    Last Post: 25-01-2016, 11:46 AM
  2. CNC Maintenance Technician Job Opportunity - SeaStar Solutions, Richmond, BC, Canada
    By Etranhirose in forum Opportunities Available & Sought
    Last Post: 10-09-2015, 12:35 AM
  3. Replies: 0
    Last Post: 08-07-2014, 03:11 PM
  4. NEW MEMBER: Technician, secondary education
    By Nic in forum New Member Introductions
    Last Post: 22-07-2011, 12:34 PM
  5. Maintenance Technician/Engineer
    By mvolt in forum Opportunities Available & Sought
    Last Post: 16-02-2011, 10:38 AM
