16-10-2018 #11
You'll have to wait and see, you don't have the rubber mounts normally associated with single phase machines, they help significantly in smoothing out the bumps in the torque output.
I noticed a significant improvement in surface finish when I converted my Myford Super 7 to 3 phase, I would never go back to single phase for a lathe or mill,
Regards,
NickYou think that's too expensive? You're not a Model Engineer are you? :D
16-10-2018 #12
The motor is bolted to the the headstock but the drive is via belts and it's spinning a big old chuck so may not be too bad.
I'll face off some ali and see if there is any sign of uneven cut.
So when you fitted a VFD, I assume you delta the motor and wire the VFD direct to it? I read that VFD's like to be close to the motor and don't like contactors etc in the way.
Did you re-wire the fwd rev microswitches to operate the VFD or just add a control pendant/box for the VFD?
I would like to retain the fd rev lever and footbrake.
16-10-2018 #13
Yes, motor Delta, wired my friend's 300 to use all the standard controls, just with a speed pot added, Fwd/Rev lever works as standard as does the foot brake.
He initially wired the motor Gamma (I named it after him) where the two ends of each winding were joined and one inverter phase was connected to each closed loop! :DYou think that's too expensive? You're not a Model Engineer are you? :D
07-11-2018 #14
In the end I managed to get a rotary inverter which works great and was fairly cheap (1/3 new price). There is definatley less vibration but I didn't check surface finish with the single phase.
Nice to have original lamp and subs pump going, along with all the switchgear kept as standard.
07-06-2021 #15
Hi all.
I have a similar question regarding single phase to 3 phase 240v/415v with an xsy-at1 VFD inverter. My 415v 5hp motor 4kw 7.3A is wired in delta for the 240v supply that I have. I am struggling to get it running properly as I’m not sure exactly what the parameters need to be set to or even which ones. Any help from someone would be much appreciated
Kirk
FOR SALE: Denford Triac VMC with ATC / Servos / Mach 3 / Single Phase / CS Labs
By Chaz in forum Items For SaleReplies: 10Last Post: 28-08-2017, 10:15 PM -
FOR SALE: Interwood/Watford overhead router single phase £840
By rainboweyes in forum Items For SaleReplies: 0Last Post: 14-10-2016, 10:31 PM -
single and 3 phase motor sizing and mounting ?
By Musht in forum General ElectronicsReplies: 5Last Post: 27-10-2013, 09:58 PM -
Big single phase servos and drivers
By m_c in forum Stepper & Servo MotorsReplies: 0Last Post: 04-09-2013, 01:18 AM -
convert 3 phase to single phase?
By D-man in forum General ElectronicsReplies: 10Last Post: 06-04-2013, 12:16 AM
