    Doddy's Avatar
    The schematic - yup, though I'd be interested in the 1c1/1c2 arrangement - these are contactors?, what actuates these? a mechanical forward/stop/reverse switch? in which case this can be re-used - which is what I think you're after?
    The other thing is to look to see if you can only energise the start coil whilst the run coil is energised - again, can be done with the 1c1/1c2 arrangement, depending on it's behaviour.
    Doddy's Avatar
    My bad - 1C1/1C2 are the relays shown at the bottom of the schematic?
    Then use two pairs of the 1c1/1c2 contacts to provide the change-over for the start coil, and the remaining contact for both 1c1 and 1c2 wired in parallel to provide the live supply to the motor run coil.
    Yes, 1c1 and 1c2 are the fwd/rev contactors operated by microswitches which are in turn operated by the motor control lever on the carriage. See bottom of schematic. Obviously they are never both closed!
    You're right, I can use the third pair of contacts to switch the run coil on/off, which I haven't shown in my sketch.
    Cheers!
    Quote Originally Posted by Richard View Post
    Cheers!
    Updated.
Name:	single phase wiring3.jpg
    I have a nice Harrison M300 lathe, which I have fitted a single phase motor to.
    I helped a friend to fit a VFD to his and convert the rest of the switch gear to 240, why on earth would you want to fit a motor providing "Lumpy Torque" to such a nice lathe?
    I had a single phase 2.2kw motor handy...
    Do you think I'll see the lumpy torque in the surface finish?
    You'll have to wait and see, you don't have the rubber mounts normally associated with single phase machines, they help significantly in smoothing out the bumps in the torque output.
    I noticed a significant improvement in surface finish when I converted my Myford Super 7 to 3 phase, I would never go back to single phase for a lathe or mill,
    Regards,
    Nick
  1. Replies: 10
    Last Post: 28-08-2017, 10:15 PM
  2. FOR SALE: Interwood/Watford overhead router single phase £840
    By rainboweyes in forum Items For Sale
    Last Post: 14-10-2016, 10:31 PM
  3. single and 3 phase motor sizing and mounting ?
    By Musht in forum General Electronics
    Last Post: 27-10-2013, 09:58 PM
  4. Big single phase servos and drivers
    Last Post: 04-09-2013, 01:18 AM
  5. convert 3 phase to single phase?
    By D-man in forum General Electronics
    Last Post: 06-04-2013, 12:16 AM
