    I've finally gotten around to fitting the ball screws to my small simple test CNC mill conversion, the ball screws were bough here second hand but pretty much unused and were a "close but no cigar" match to my mill so yesterday I slung them in the lathe to adjust the end dimensions to fit.
    The cuts on the X axis screw were within the annealed areas but for the Y axis screw I needed to go into the hard section and didn't fancy hitting it with a blow torch and wet rag, so, after trying a couple of styles of carbide insert I remembered I had a box of CBN hard turning inserts, I stuck one in a holder and all I can say is "Knife through Butter".
    The shiny bit is the Hard Turning, the rest was already done when I got the screws.
  2. The Following User Says Thank You to magicniner For This Useful Post:
  3. #2
    Lives in Plymouth, United Kingdom. Last Activity: 20 Hours Ago Has a total post count of 1,749. Received thanks 299 times, giving thanks to others 11 times.
    Interesting result. Is the original bit of machining as rough as it looks? I know that photographs are often misleading when it comes to surface finish. And can you use the existing thread, or are CBN threading inserts available? I've never looked past carbide in the catalogues - prices go up as you turn the pages...
    And for completeness, what lathe were you using? Possibly not using the kinds of speeds/feeds/DOC that a "hobby-class" machine could achieve?
    Almost ;-)
    Myford Super 7 Long Bed, 1hp, 3 phase, at 2000rpm and 0.2mm DOC, manual feed so the material comes off like angel's hair on fire :D
    My head stock is a special with 30.5mm through capacity and a native ER40 nose taper but with a register and back plates with 3 & 4 jaw chucks but I still have the standard top slide with an RDG copy of the Dickson QCTP.
  1. BUILD LOG: I've built this machine 100 different times in my head!!!
    By Iwant1 in forum DIY Router Build Logs
    Last Post: 13-06-2017, 08:18 PM
  2. FOR SALE: Basic vacuum table setup 400x200- used 1-2 times
    Last Post: 02-04-2016, 09:07 PM
  3. Turning hard materials
    By Harry Hills in forum Metalwork Discussion
    Last Post: 07-02-2016, 04:49 PM
  4. Best place for hard stops?
    By mitchejc in forum Gantry/Router Machines & Building
    Last Post: 25-11-2014, 06:39 AM
  5. RFQ: Why is it so hard...
    By ktc in forum Projects, Jobs & Requests
    Last Post: 11-08-2013, 08:05 PM
