Thread: 'Otter'. Build log.
	22-10-2018 #1
The 'Otter' CNC machine I am building is based on rigidity for harder materials for smaller jobs and versatility for larger jobs with softer materials.
I have collected a small amount of essential parts to build my machine. I will continue to post images as I progress the 3D design, procure more items for the build and as I make parts for the machine.
I am a beginner as the last workshop I was actively part of was about 25 years ago and plenty of skills have been lost over time since then. :-(
So here goes, any criticism is welcome to help improve my build.
Current parts list:
8x 100x50x3x1250 cold finished hollow section Strongbox 235 EN 10219:2006 grade S235JRH BSEN10204 2.2CERT
4x NEMA 23 3Nm 3Amp stepper motors
[s] 6x TB6600 micro-stepping drivers (2x redundant spares)[/s] Amazon lost them before delivery
Still to buy:
Bed plate
Linear rails and bearings
Ballscrews
Cable tray and chain
Stepper motor drivers
VFD
Motion control unit
Power supply unit
Workpiece coolant mister system
Cooling pump for spindle
ATC spindle
Vaccuum and compressed air cleaning system
Future upgrades:
Auto tool changer built with above Otter CNC
I'm currently researching Hiwin linear rails and bearings but they are hellishly expensive on the web sites I have found. I don't want to cheap-out on rails and bearings as I need a fair amount of accuracy and would like to machine harder materials, minimising vibration. Any help finding cheaper but still good quality linear rails and bearings would be welcome.
[s]I'm also not sure about the TB6600 stepper motor drivers as they seem fairly cheap and I have absolutely no idea what would be required of a more capable machine. They seem to cover the requirements of the NEMA 23 motors, with micro-stepping and current limiting. Are there any problems with these and if so are there better alternatives?[/s] Amazon failed to deliver and there are much better alternatives.
I've been messing around with GRBL but have not settled with a motion control solution yet. I am not familiar with GRBL's capabilities and could quite easily be encouraged to research a more established standard of motion control, as long as it's reasonably economical to implement. This appears to be the smallest challenge considering that the physical build will be much more demanding as far as calibration and physical tweaking are concerned.
I will be starting to build a frame for the table with the steel box section next weekend. I have zero welding skills so I'm considering drilling precision holes and using substantial bolts to fit brackets that will secure the frame both outside and inside. This should be just as good, if not better, than any weld for rigidity.
That's about it for now. Any comments and suggestions would be appreciated.
BBBLast edited by Blazing Black Beard; 24-10-2018 at 04:56 PM. Reason: Removed stepper motor drivers as Amazon lost them
	22-10-2018 #2
Hi B3
Welcome to the forum
The first rule of any build is not to buy any of the electrics until you have everything designed in CAD/Sketchup. then offer it up for the guys to look over, they will put you right regarding things you might have overlooked. Most of the guys tend to buy ther rails and ballscrews from Fred, He will supply Hiwin and the cheaper generic stuff, best to get it all in one shipment, you will have to pay import duty ect, but he has a good reputation on the forum and will rectify any problems with gear thats not as described.
If i (or some other kind soul) can find a link to Freds shop i will post it.
Good luck with the build.
regards
Mike
Just a couple of links i had saved not sure if the first one is Fred's
https://www.aliexpress.com/store/pro...612.0.0.PXFXn5
https://www.aliexpress.com/item/HIWI...999.263.UMYDXNLast edited by mekanik; 22-10-2018 at 03:18 PM.
The Following User Says Thank You to mekanik For This Useful Post:
	22-10-2018 #3
Thanks for that mekanik. After reading a few builds the motors I chose seemed to be what everyone else is using. Would you say I made a bit of a rushed decision to get NEMA 23 3NM motors and drivers?
I got the steel box section as I thought it would be more rigid and provide the extra weight needed to machine harder materials and minimise vibration. I didn't think architectural construction steel (which is what this seems to be) would be any less suitable than other types as it's already way more rigid than aluminium extrusion. Is there anything you or anyone else can offer regarding this choice or alternatives?
I will be sending images of my initial design for you guys to look at and see if I'm doing OK or missing some fundemental considerations.
Thanks again for the links. I'll check them out and compare prices and as always, I'm looking to shave anything off the costs of this build as long as it doesn't take away too much quality or precision. I want to get it right :-)
	22-10-2018 #4
Black Beard - take a look at my "Avor" build. I wouldn't necessarily recommend that you (or anyone else) tries to copy it, but you might get a feel for the kinds of things that go into a machine like this. For example, those stepper drivers will very significantly limit performance.
As suggested, ask more questions before buying too much more, but welded steel box, Hiwin-style rails and ballscrews can give a very capable machine - I've recently been profile cutting small steel components with mine. Good luck with the build!
	22-10-2018 #5
Thanks for the info. I'm checking out your build now. I don't have any experience with any CNC stepper drivers. If they are going to severely limit the machine they can be easily replaced with something more capable. I'm open to suggestions and any other information about stepper drivers that may help. Is there anything in particular I should be looking out for with better drivers?
	23-10-2018 #6
Ah, Tata Steel product! Can I ask where did you get it?
I would have chosen their Celsius 355 product instead, which is already stress relieved.
Also, you can't just bolt steel tubes and expect a good joint. The contact surface will be poor. You need to first bond the tubes with something like a steel-filled epoxy, and then bolt.Last edited by jarjar; 23-10-2018 at 10:16 AM.
The Following User Says Thank You to jarjar For This Useful Post:
	23-10-2018 #7
Hello jarjar. Welcome. To my build log.
As my first post suggests, total novice here. Stress relieved? I'm not sure what that means. I chose this steel box section because it was half the price of anything else I could get my hands on and seemed a much more suitable and rigid material than aluminium. I didn't know different types of box section steel would be more suited.
What is their Celsius 355 product? I'm afraid I did not do much research into the types of steel box section available apart from dimensions. Maybe a bad move on my part? Any comments on this would be appreciated.
Neale, I took a good look at your posts before starting this log and this is where I got a lot of my rigidity ideas from. Although now it seems I have got myself some steel that may not be as good as yours, we will see. I hope the steel box section I have is not going to be a major drawback. If it is then please let me know.
I'm hoping to make a start to the 3D design over the next couple of days and I will post some images of my progress.Last edited by Blazing Black Beard; 23-10-2018 at 02:52 PM.
	23-10-2018 #8
I know this is not something I should really be considering to buy so early on in the design stage but I could not help but take a look around at spindles. There's a mind boggling amount available out there and one that especially caught my eye was this:
https://youtu.be/pWNeW-lH9RA
Any comments regarding suitability or alternatives would be appreciated.Last edited by Blazing Black Beard; 23-10-2018 at 02:57 PM.
	23-10-2018 #9
Don't worry about the steel quality - I didn't! I just bought something from my local steel supplier, probably generic "construction" steel. Doubt if it's stress-relieved or anything else. It is described as "Grade 43a", whatever that means. Welds and cuts OK, and I knew from the outset that I would need to build in adjustment/levelling, etc. Being fussy about steel quality is OK if you can actually buy the quality you are after in small enough quantities (a lot of suppliers will charge more in carriage than the cost of a small quantity of steel - that's not criticism, just a reflection of commercial reality) and if your design is actually sensitive to the steel quality. My design, such as it is, could be beefed up significantly by using, say, 4mm wall thickness rather than 3mm, and for the static bed and frame components, that might not have been a bad idea. However, 3mm works fine for the gantry and does keep mass down.
Don't think you've said how big this is going to be, or what you want to cut on it. This drives some aspects of the design. For example, my machine has about 1.5x0.75m cutting area. For that, I have used 2005 ballscrews. If I were only cutting wood, then 2010 would have been better - faster rapids and cutting speeds. However, I end up doing quite a lot of small fiddly bits and the speed isn't too critical so 2005 works well for me. Similarly, I use NEMA23 3Nm motors; for faster speeds I could have gone to 4Nm for a bit more torque but I'm OK at the moment. However, stepper motors need volts to get performance out of them; don't be confused by spec sheets that say things like "4.2V". That's a red herring. Most of these size motors will work best from about a power supply giving about 68V via a suitable stepper driver. There are plenty of threads that look at different drivers and how to build power supplies.
I'm using a "standard" 2.2KW spindle and matching VFD. Don't know much about ATC spindles apart from the fact that a decent one will cost big bucks.
	23-10-2018 #10
Neale again thanks for all the info. My gantry will be somewhat like yours I assume so my 3mm thick 100x50x1250 box section should do fine for the X axis (left to right on gantry and table ends).
I will be cutting small aluminium parts with high accuracy and superior finish, larger aluminium plate with accurate hole cutting but still relatively small compared to the size of the machine which will be approximately 1000mm x 1500mm cutting area footprint. I also aim to easily cut steel sheet and small accurate steel parts from time to time.
As for the ballscrews, I seem to keep reading that 20mm diameter x 5mm thread seems to be pretty common and you use them, so I think I may settle for these when I come to buy the rest of the components after I have finished the first phase of the 3D design.
I know virtually nothing about spindles or their VFDs. You mention 4Nm for the NEMA 23 motors. I'm assuming the holding force is better for heavier gantry arrangements that have more inertia, therefore need more force to ramp speeds without skipping position? Looking at motors and drivers is as mind boggling as spindles and the various (and sometimes exotic) materials that some people use in their builds.
I have been looking at a marble bed and gantry arrangement and I am having a hard time drawing myself away from that expensive venture (eek!). I don't think I will ever do it but it's hard to stop looking at these machines and what I am inclined to think about their accuracy. They must be extremely rigid and very heavy, not to mention unwieldy should one want to move the machine for any reason. I can also imagine that accidents on a marble bed/gantry machines can be costly.
Anyway, back to the real world where I think I will stick with a 100x50x1250 box section gantry. Would moving to 4mm-6mm thickness be of any benefit for my 1800mm sides? Is there going to be any benefit from using thicker box section on the top part of my bed frame? I'm guessing that the rigidity of the 4+mm box section is only of any benefit where there is an axis directly connected with linear rail and bearings and the thinner 3mm box section would be adequate to form the lower part of the frame and the supporting uprights and diagonals? Does that sound about right or am I missing something?Last edited by Blazing Black Beard; 23-10-2018 at 05:20 PM.
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
