  1. #13
    Most people just use the standard box section, if you are welding there will be distortion you can reduce this somewhat by just stitch welding it, doesn't have to be full weld. the distortion in the base (X) axis is is eliminated with epoxy grout levelling.
    Regards
    Mike
    How can the face on the side of the box section be used to keep the rails parallel though? These can't be poured with epoxy as it would just run down and onto the floor.
    If you look at RoboCNC you'll see he just uses the straight vertical face on the side of the aluminium to keep his linear rails parallel and straight.https://youtu.be/YOVHtjXi07Q?t=2m02s
