    Quote Originally Posted by Blazing Black Beard View Post
    8x 100x50x3x1250 cold finished hollow section Strongbox 235 EN 10219:2006 grade S235JRH BSEN10204 2.2CERT
    Ah, Tata Steel product! Can I ask where did you get it?
    I would have chosen their Celsius 355 product instead, which is already stress relieved.
    Also, you can't just bolt steel tubes and expect a good joint. The contact surface will be poor. You need to first bond the tubes with something like a steel-filled epoxy, and then bolt.
  2. The Following User Says Thank You to jarjar For This Useful Post:
  3. #2
    Quote Originally Posted by jarjar View Post
    Hello jarjar. Welcome. To my build log.
    As my first post suggests, total novice here. Stress relieved? I'm not sure what that means. I chose this steel box section because it was half the price of anything else I could get my hands on and seemed a much more suitable and rigid material than aluminium. I didn't know different types of box section steel would be more suited.
    What is their Celsius 355 product? I'm afraid I did not do much research into the types of steel box section available apart from dimensions. Maybe a bad move on my part? Any comments on this would be appreciated.
    Neale, I took a good look at your posts before starting this log and this is where I got a lot of my rigidity ideas from. Although now it seems I have got myself some steel that may not be as good as yours, we will see. I hope the steel box section I have is not going to be a major drawback. If it is then please let me know.
    I'm hoping to make a start to the 3D design over the next couple of days and I will post some images of my progress.
    Lives in Plymouth, United Kingdom. Last Activity: 4 Weeks Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    Don't worry about the steel quality - I didn't! I just bought something from my local steel supplier, probably generic "construction" steel. Doubt if it's stress-relieved or anything else. It is described as "Grade 43a", whatever that means. Welds and cuts OK, and I knew from the outset that I would need to build in adjustment/levelling, etc. Being fussy about steel quality is OK if you can actually buy the quality you are after in small enough quantities (a lot of suppliers will charge more in carriage than the cost of a small quantity of steel - that's not criticism, just a reflection of commercial reality) and if your design is actually sensitive to the steel quality. My design, such as it is, could be beefed up significantly by using, say, 4mm wall thickness rather than 3mm, and for the static bed and frame components, that might not have been a bad idea. However, 3mm works fine for the gantry and does keep mass down.
    Don't think you've said how big this is going to be, or what you want to cut on it. This drives some aspects of the design. For example, my machine has about 1.5x0.75m cutting area. For that, I have used 2005 ballscrews. If I were only cutting wood, then 2010 would have been better - faster rapids and cutting speeds. However, I end up doing quite a lot of small fiddly bits and the speed isn't too critical so 2005 works well for me. Similarly, I use NEMA23 3Nm motors; for faster speeds I could have gone to 4Nm for a bit more torque but I'm OK at the moment. However, stepper motors need volts to get performance out of them; don't be confused by spec sheets that say things like "4.2V". That's a red herring. Most of these size motors will work best from about a power supply giving about 68V via a suitable stepper driver. There are plenty of threads that look at different drivers and how to build power supplies.
    I'm using a "standard" 2.2KW spindle and matching VFD. Don't know much about ATC spindles apart from the fact that a decent one will cost big bucks.
  5. The Following User Says Thank You to Neale For This Useful Post:
  6. #4
    Neale again thanks for all the info. My gantry will be somewhat like yours I assume so my 3mm thick 100x50x1250 box section should do fine for the X axis (left to right on gantry and table ends).
    I will be cutting small aluminium parts with high accuracy and superior finish, larger aluminium plate with accurate hole cutting but still relatively small compared to the size of the machine which will be approximately 1000mm x 1500mm cutting area footprint. I also aim to easily cut steel sheet and small accurate steel parts from time to time.
    As for the ballscrews, I seem to keep reading that 20mm diameter x 5mm thread seems to be pretty common and you use them, so I think I may settle for these when I come to buy the rest of the components after I have finished the first phase of the 3D design.
    I know virtually nothing about spindles or their VFDs. You mention 4Nm for the NEMA 23 motors. I'm assuming the holding force is better for heavier gantry arrangements that have more inertia, therefore need more force to ramp speeds without skipping position? Looking at motors and drivers is as mind boggling as spindles and the various (and sometimes exotic) materials that some people use in their builds.
    I have been looking at a marble bed and gantry arrangement and I am having a hard time drawing myself away from that expensive venture (eek!). I don't think I will ever do it but it's hard to stop looking at these machines and what I am inclined to think about their accuracy. They must be extremely rigid and very heavy, not to mention unwieldy should one want to move the machine for any reason. I can also imagine that accidents on a marble bed/gantry machines can be costly.
    Anyway, back to the real world where I think I will stick with a 100x50x1250 box section gantry. Would moving to 4mm-6mm thickness be of any benefit for my 1800mm sides? Is there going to be any benefit from using thicker box section on the top part of my bed frame? I'm guessing that the rigidity of the 4+mm box section is only of any benefit where there is an axis directly connected with linear rail and bearings and the thinner 3mm box section would be adequate to form the lower part of the frame and the supporting uprights and diagonals? Does that sound about right or am I missing something?
  7. #5
    There's a really useful motor/ballscrew calculator spreadsheet somewhere on this forum which I found really useful, though I can't seem to find it at the mo. - worth digging out and putting in your predicted mass/lengths/desired speed to see what motor/power supply suits.
    On the subject of steel tubes I stumbled across this last week whilst looking for something else:
    https://www.barrettsteel.com/product...recision-tube/
    other vendors seem to do similar products, it appears that the straightness spec. is better than normal stuff.
  8. The Following User Says Thank You to Voicecoil For This Useful Post:
  9. #6
    Voicecoil thanks for that. I'll try to dig out the spreadsheet.
    Good point about the straightness spec. I may just use the 100x50x3 section as strengtheners in the lower part of the frame if it's not as straight as required. Is there any way I can check the straightness and rectify the rails should I need to? I can see lining up the rails might be an issue if I just use a gauge and the face of this box section should it not be adequately straight.
  10. #7
    I would say that a decent long straight edge and a large square are pretty essential when building a machine - unless you happen to have access to a large surface table of course!
