  1. #4
    Some pics of the beasty.
    Hiwin rails and slides all round. 16mm ball screws.
    Z axis has moving rails, which is good.
    It's made partly from extrusions and partly from plate.
    Gantry uprights are quite tall and might be a bit floppy but they are 20mm thick.
    Everything feels nice and tight where it needs to be.
    Bed is not shown, it's a slab of 15mm cast iron with an ali plate bolted onto that, which has been drilled and tapped in a grid.
    Spindle feels smooth and vibration free.
    Appears to be set up for spray mist. There's a line running to a valve mounted (or rather strapped on) on the front of the spindle which would take a liquid feed I assume. There's only an air line there at the moment.
Name:	20181025_172134 (Medium).jpg
ID:	24958Click image for larger version.
Name:	20181025_172252 (Medium).jpg
ID:	24957Click image for larger version.
Name:	20181025_172048 (Medium).jpg
ID:	24959Click image for larger version.
Name:	20181025_172030 (Medium).jpg
ID:	24960Click image for larger version.
Name:	20181025_172009 (Medium).jpg
  1. NEW MEMBER: Just checking if this works
    By jamesd256 in forum New Member Introductions
    Last Post: 01-09-2016, 11:38 AM
  2. NEW MEMBER: New to CNC and need some tips for what to look for when buying a laser cnc
    By veviben in forum New Member Introductions
    Last Post: 12-12-2014, 09:28 PM
  3. NEW MEMBER: Checking in for an introduction.
    By Steve V. in forum New Member Introductions
    Last Post: 06-09-2010, 07:45 AM
  4. Looking for tips on making 2.5 x 1.25 mtr table
    By psiron in forum Gantry/Router Machines & Building
    Last Post: 14-06-2010, 08:09 PM
  5. Bridgeport Tips & Advice
    By Philmollatt in forum Milling Machines, Builds & Conversions
    Last Post: 01-10-2009, 06:34 PM
