    Hi, ive done a search but i could not find a clear answer. Ive got a WM18 warco mill that in total weighs about 220kg. Im looking to add steppers so i can use them as a powerfeed initially (maybe to use as a CNC later). Im thinking of using a 2 to 1 belt drive with the existing screws, and i heard someone say you need around 4.5nm of torque.
    The only 4.5nm ones ive found at Nema34
    https://www.cnc4you.co.uk/Stepper-Mo...4808-02-Nema34
    On my router ive used these which are Nema24
    https://www.cnc4you.co.uk/Stepper-Mo...H401-03-Nema23
    If anyone can give me a idea of the required stepper size that would be great.
    Trev
    Lives in Marple Stockport, United Kingdom. Last Activity: 18 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by Gotty101 View Post
    Trev
    Trev I have converted the WM18 to CNC I used nema23 from cnc4you BUT is used ball screws not the original lead screws.
    I geared the screws down 2:1 with belts.
    Thanks for the reply Clive. Was it the 4nm ones you used?
    It was the 3.2 for x and y. 4 on z. But remember you have a bigger advantage with ball screws
    Thanks Clive,
    Ill get the 4NM ones then.
    Trev
    Thanks Clive,
    Trev
    It would be a bit of shame to go to all the work of fitting motors and not changing the screws
    Trev
    Hi Trev. I'm looking at getting a similar machine AMAT30LV when it comes in stock. Belted drive instead of geared.
    I'm using 425oz nema 23 on my SeigX2 and I'll be using the same for the x,y table on the Amadeal. But on the head I'm going to use a 1600oz nema34.
    Should be plenty. Have got the electrics already from Wantmotor on ebay. I got my X axis on the Seig down to 0.03mm backlash with a 1605 screw attached. I'll be happy if I get that on the new one. I recommend using screened cable. I only use the soft limits on the Sieg (no switches) and still get noise in the system from the pc so I regret not going for screened. Sometimes they have a bumping noise and sometimes not.
    Lesson now learned.
  1. Warco WM16 Mill - Conversion to AC motor with VFD
    Last Post: 10-02-2022, 07:41 PM
  2. Help and Advice sought about new motor for my mill
    By alanb in forum Milling Machines, Builds & Conversions
    Last Post: 26-01-2012, 08:04 PM
  3. FOR SALE: (G0704 SPG 2217 Champion 20V Mill Warco WM 16) DC motor
    By fragger6662000 in forum Items For Sale
    Last Post: 09-10-2011, 05:59 PM
  4. Stepper motor advice for absolute novice
    By mbgnjdb5 in forum Stepper & Servo Motors
    Last Post: 07-05-2011, 04:47 PM
  5. Wabeco F1410LF vs Warco WM18 vs Sieg X3
    By abfa9358 in forum Milling Machines, Builds & Conversions
    Last Post: 02-08-2009, 08:23 AM
