    Quote Originally Posted by john swift View Post
    As I don't have the longs kit to test, I don't have a definitive answer but
    problems the original breakout board will only show up at high speeds
    the original motor / driver combination may limit the maximum motor speed first
    without going through all the stepper motors , stepper drivers and power supplies on sale
    its not easy to say which is the most cost effective change
    using a higher voltage supply & stepper drivers verses replacing the motors with lower inductance motors
    John
    A very informative and educational reply! Allows me to analyse motor and driver specs with a little more knowledge than I had yesterday. Thanks for taking time to explain things in such detail.
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,984. Received thanks 369 times, giving thanks to others 9 times.
    It's worth highlighting the main reason opto-isolators are added to BOBs is for protection.
    Using a parallel port, get something wired wrong, or have something short and connect power to pins they can't withstand, then more than likely your PCs parallel port (and likely entire motherboard) will be dead.
    With newer motion controllers, the path of destruction from a wiring problem isn't likely to be as long, but it's still potentially a couple hundred pound controller that could be releasing it's magic smoke.
    It's a calculated risk not using them, but at slow speeds, they shouldn't cause any problems. I certainly wouldn't be searching out a BOB without them, unless I was really going to be pushing pulse rates.
    Regarding suitable motors.
    A good starting point would be to try and find out the torque for the existing motors, or even a datasheet with torque curve (it's surprising what a google for the model number turns up).
    You can then run a few figures and see how the various options compare. You'll likely find some suitably geared NEMA23/4s provide better performance than NEMA34s directly coupled, especially when running from lower voltage.
    I would Not retrofit a precision metal cutting machine with an Open Loop system , given prices of new cheap servo motors and drives, used servo motors and drives and closed looped steppers which i dont like much pricewise
    adding more detail to post 7 for any one wanting to use a BOB with opto-isolated outputs and stepper drivers with opto-isolated inputs
    the problem with the BOB supplied as part of the kit is ue use of the slow PC817 opto-isolators used for the outputs
    I would expect the DM860A stepper drivers would have a PC817 on the enable input and a high speed isolator like a HCPL2531 for the step and direction inputs
    as used on this Tormach driver input
Name:	10 pin connections 3.jpg
    the diagram is from
    https://www.cnczone.com/forums/torma...ml#post2107952
    if I used a breakout with opto-isolated outputs then I would look for a BOB like this -
    https://cnc4you.co.uk/resources/Brea...ard%20HG08.pdf
    or this
    http://www.electronics-lab.com/proje...r-cnc-routers/
    they are just two of example found
    John
  1. Sieg X3 size conversion kits - what is available?
    By men8ifr in forum Milling Machines, Builds & Conversions
    Last Post: 13-10-2018, 05:06 PM
  2. eBay: Bridgeport J Series Turret Mill
    By steve400 in forum Items On eBay UK
    Last Post: 24-04-2017, 04:11 PM
  3. Bridgeport series 1 MDI / CNC tooling
    By drumsticksplinter in forum Milling Machines, Builds & Conversions
    Last Post: 08-03-2013, 04:47 PM
  4. Complete conversion kits?
    By leitzscope in forum General Discussion
    Last Post: 01-05-2010, 07:57 PM
