    These will stunt the machine, if you can go with AM882 (not easy to find now) or https://www.ebay.co.uk/itm/2DM860H-2...-/401403682399 with a 68V power supply
    Just been looking into AM882 drivers. They offer three variations - AM882, AM882H, DMA882S. According to the details the AM882H has "fun" but the AM882 has "no fun" and it seems both are being replaced by the DMA882S. Whichever version I choose I am looking at about £200 for four drives. I can get four 2DM860 drives for about £150.
    Is it worth spending the extra £50 or so for the AM882s over the 2DM860s? If I go for the AM882s, is it better to get the tried and tested AM882 or AM882H, OR do I get the latest DMA882S?
    AM882 Drives:
    2DM860 Drives:
    Quote Originally Posted by CaptainBarnacles View Post
    AM882 Drives:
    2DM860 Drives:
    The drive I linked to is the H version and shows : Supply voltage 30VAC (DC40V) ~ 80VAC (DC110V) this means you could just put a toroidal transformer connected to it because the drives can accept AC as well as DC
    Your link shows 48-75VDC, power supply, which is a bit low for a 68V power supply.
    I have used the 2DM860H several time and not had any problems
    Aaaahhh, I see. Thanks Clive, I'll get the 2DM860H drives that you linked to.
    Cheers,
    Paul.
    Just before I push the button on a transformer could I just have a quick sanity check please?
    Here's my thinking:
    I have 4 qty 3A max steppers and I've ordered 4 qty 2DM860H drivers. I reckon that it's highly unlikely to have all four motors chugging away pulling 3A each at any given time so I've assumed 10A as the max draw. The drivers will take AC so I won't have voltage drops and capacitance calcs to take into consideration. I am looking at a toroidal transformer with 2x35V AC secondary windings in series ie 70V AC (the drivers are rated up to 80V AC). Therefor 10A * 70V = 700VA (750VA is the closest standard size).
    Am I missing anything?
    Lives in Plymouth, United Kingdom. Last Activity: 18 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    Can't argue with your arithmetic, but the usual choice is 650VA. In fact, I ran mine with a 500VA toroidal for some time, until it failed. I don't believe that the failure was due to overloading - just one of those things - as it never became particularly warm. I went for one size up because it cost very little more and fitted the space available. There are a few factors here which mean that you tend to get more volts than you would expect. One of these factors is that the transformers will often deliver 5% or so over the nominal value on the basis that it will drop to nominal at full load. 2X35V in series will give you more than you expect, and input mains voltage is also often above nominal so the output volts go up a bit there. Keep this in mind when you are looking at the max voltage input of your drivers.
    Plus one.
    Thanks for that Neale. Good point about the output voltage. I have the option of 2x35V, 2x30V or 2x33V (from different suppliers), I think I'll plump for a slightly lower voltage just to be on the safe side.
    Is there anything to be gained from using 4 qty 160VA transformers over a single 625VA? My thinking is that I could assign a transformer to each driver. I can get the 4 160's for about £15 more than a single 625VA so the price difference is neither here nor there. I suppose it would be cheaper to replace a 160VA in the even of a transformer failure but I wondered if there was any performance benefit to the system?
  8. The Following User Says Thank You to CaptainBarnacles For This Useful Post:
  9. #8
    Can't think of any particular advantage of 4 individual transformers, except that it enforces good wiring practice - separate connections from PSU/transformer to drivers, with no daisy-chaining from one to another. Yes, could replace one if it fails, but you need more space to mount them. Swings and roundabouts!
  1. Aluminium profile cnc build
    By valdis034 in forum Gantry/Router Machines & Building
    Last Post: 21-02-2023, 02:27 PM
  2. BUILD LOG: Large aluminium profile build
    By jeronimo in forum DIY Router Build Logs
    Last Post: 12-11-2016, 10:02 PM
  3. 600 x 400 Aluminium Profile Gantry Router
    By Journeyman in forum Gantry/Router Machines & Building
    Last Post: 02-03-2016, 04:28 PM
  4. aluminium profile for cutting bed of router
  5. BUILD LOG: New build - fixed gantry mill using extruded profile
