    Chaz's Avatar
    Id like to connect some Analog drives to my Acorn board (step / direction). It looks like there have been a few attempts at getting something to run that can modify signals like this. Anyone aware of an off the shelf product that might suit or am I better off looking at step / direction servos?
    In theory if you have a micro-controller with D to A which gives the required resolution you could write a fairly simple program to vary the Analogue output based on step and direction inputs.
    Chaz's Avatar
    That's what I thought too, doesnt sound too difficult to solve, does it?
    Chaz's Avatar
    So it's been pointed out that the Panasonic drives I have (And are looking to use for the Lathe) can take Step / Direction. Its called Command Pulse.
    Lives in East Lothian, United Kingdom. Last Activity: 14 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,990. Received thanks 374 times, giving thanks to others 9 times.
    For basic step/dir to analogue, it's fairly straightforward, and there are a few options about, all aimed at spindle control where open loop is usually fine.
    The problem is you want to close the loop, which means the interface has not only got to accept the step/dir, it also has to be able to take an encoder input, and control the analogue output with PID parameters. Sounds simple, but given the development involved, support costs, and the relatively few likely to sell, it's not really viable. I'd guess you'd be looking at over £80 per interface to make it commercially viable.
    For anybody wanting to use analogue drives, it's usually cheaper to just buy an analogue capable controller.
    I do seem to remember there was one available at some point, and IIRC it was mentioned on the Machsupport forum, although I don't remember anybody who actually used any.
    However, as you've discovered, most digital drives do support step/dir. It's ye olde analogue amplifiers that are stuck on analogue.
    The Larken Step2Linear board can convert step/dir to analog.
    http://www.viperservo.com/
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  1. How to find the right pin and Port for my PWM / and or Analog voltage output?
    By jhonansaro in forum Gantry/Router Machines & Building
    Last Post: 02-05-2018, 04:56 AM
  2. digital to analog servos
    By elad1987 in forum Control Hardware & Systems
    Last Post: 15-06-2017, 09:59 PM
  3. Step/Dir vs Pul/Dir
    By iforeman in forum Motor Drivers & Controllers
    Last Post: 02-05-2017, 01:18 PM
  4. Replies: 9
    Last Post: 16-04-2017, 06:38 PM
  5. op-amp to drive +/-10V analog servo from old +/-5V controller
    By paulus.v in forum Motor Drivers & Controllers
    Last Post: 14-02-2017, 08:33 PM
