    I am doing a conversion on a Novamill and require a couple of pins for the connector socket.
    The plug has a name contart on it. there is a ref. on the docs for the pin "male insert B1 357 H
    Any clue as to where I could get them and do they need a tool to insert them.
    Lives in East Lothian, United Kingdom. Last Activity: 9 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,991. Received thanks 375 times, giving thanks to others 9 times.
    RS do the bits, but I can't find the details right now.
    Don't know why that has got Contart on it, but it's a Harting connector system.
    I can tell you the release tool is RS part no 114-7728, as I had to buy one to swap a few things around on my Triac. I thought I had also ordered the terminals, but a search of my email isn't showing any relevant orders other than for the release tool.
    That's very helpful, thanks.
    Would you say it was this one https://uk.rs-online.com/web/p/heavy...ctors/1444239/
    I have found this pin https://uk.rs-online.com/web/p/heavy...ories/0408319/ £3.74 pk 10 + vat
    or this https://uk.rs-online.com/web/p/heavy...ories/1567267/ £34 pk 50 +vat bit steep I only need two
  5. #4
    The relevant Harting catalogue for that connector should be attached, so probably best to double check measurements/contacts, as the Triac uses more terminals. I'm pretty sure they still use the same series of connector, just the Triac has two more rectangular modules in the housing.
    I thought I had ordered contacts, but I can't find any or any evidence of ordering them. I suspect I may of just reused contacts, as they require a circular crimp tool which I definitely don't have. If you crimp them with normal crimping pliers they might not fit the housing, as they are quite a tight fit.
  6. #5
    Thanks for the info.
    I ordered these https://uk.rs-online.com/web/p/heavy...ories/0408319/ 4pm last night and they were here by 12 noon.
    I soldered the cables into the pins and slid them in from the back. simples. So now I have enough cables to change the feed & speed pots to alps encoders.
  1. Which circular connector for spindle
    By ROBCNCAU in forum Spindles & Drive Motors
    Last Post: 19-06-2016, 09:20 AM
  2. Connector for THC ?
    Last Post: 13-06-2014, 02:51 PM
  3. Spindle water hose connector
    By cncJim in forum Marketplace Discussion
    Last Post: 20-02-2014, 11:22 AM
  4. Cable + Connector issues
    By tom3d in forum General Electronics
    Last Post: 09-01-2012, 07:56 PM
  5. limit switch connector options?
    By routercnc in forum General Electronics
    Last Post: 04-09-2010, 02:11 PM
