Thread: is surface grinding worth it ?!
I would not bother with grinding for round rails.
Save the money and spend it on profile linear bearings (hiwin, thk etc)
11-11-2018 #2
For my build, which uses supported round rails, I just bolted them strait to the steel tube.
The whole thing is bolted together, not welded.
I checked the flatness of the steel with a length of aluminium extrusion I had lying around and a feeler gauge (it was the straightest thing have), and the steel was only out by a max of 0.15mm. The measurement was repeatable using both sides of the aluminium.
When i get around to final assembly i might shim the low spots to try and remove the small errors.
12-11-2018 #3
Since i don't have money for a a square linear rail and grinding the square tubing wouldn't save enough money for square rails I guess i am gonna follow in @diycncs' foot steps.
RFQ: Surface grinding Gloucestershire.
By garulus in forum Projects, Jobs & RequestsReplies: 0Last Post: 15-06-2018, 02:26 PM -
Dressing Grinding Wheels
By T0rnado69 in forum Metalwork DiscussionReplies: 5Last Post: 28-10-2014, 03:00 AM -
surface grinding / UK
By dsc in forum General DiscussionReplies: 3Last Post: 12-09-2014, 07:00 PM -
RFQ: Surface grinding quote
By Danielroyal25 in forum Projects, Jobs & RequestsReplies: 0Last Post: 15-06-2014, 03:42 PM
