  1. #4
    Lives in East Lothian, United Kingdom. Last Activity: 7 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,984. Received thanks 369 times, giving thanks to others 9 times.
    I would of thought a ribbed design would be better for the main section. That way you could get a reasonably nice L/Boomerang type shape going from the main body up to the vertical surface for the rails.
    I could be wrong, but I have something in my mind telling me U-shapes are just about as good as an enclosed box section, but it's not really something I know that much about.
    I think given the size and potential cost of the project, I'd be spending some time drawing things up in 3D software and running some FEA to see what works/doesn't work. A counter balance might be a reasonable idea, but a couple gas struts would probably be enough and reduce complexity. A quick google shows struts are available with up to 2500N (~250KG) force for not that much money (14mm rod with 500mm of stroke is available for £40+VAT from - https://gasstruts.metrol.com/fixed-f...ut-f-sd04.html )
  2. The Following User Says Thank You to m_c For This Useful Post:
  1. BOB suitable for 3 axis+ B/C head build?
    By marbles in forum Motor Drivers & Controllers
    Last Post: 20-07-2018, 09:43 PM
  2. Rails and Series extrusions
    By CrazeUK in forum Rails, Guideways & Bearings
    Last Post: 04-03-2017, 11:11 AM
  3. Bridgeport series 1 MDI / CNC tooling
    By drumsticksplinter in forum Milling Machines, Builds & Conversions
    Last Post: 08-03-2013, 04:47 PM
  4. Steppers, Series, Parallel
    By Ricardoco in forum Stepper & Servo Motors
    Last Post: 12-01-2013, 08:28 PM
  5. Mitsubishi FR-D700 Series VFD
    By acollins in forum Motor Drivers & Controllers
    Last Post: 31-05-2012, 07:24 AM
