14-11-2018 #2
Mike,
In order to avoid unpleasant surprises you ideally need to choose a machine which someone else has converted and documented, this way you will know in advance what will fit where and what machining is required, it's worth spending a little more to avoid any pitfalls.
Spindle wise I suggest you get it running CNC first, chances are you can then make what you need to mount the spindle of your choice.
I'm in the process of converting a Chester Century VS, I bought it because the price was right but I was really lucky with it, there is no major machining of the existing parts required to accommodate 16mm ball screws on the same centre lines as the original lead screws, additionally the existing mounting points for end-float bearings will work for the ball screws.
NickYou think that's too expensive? You're not a Model Engineer are you? :D
The Following User Says Thank You to magicniner For This Useful Post:
CONVERSION: Warco WM18 Mill Stepper motor advice
By Gotty101 in forum Conversion Build LogsReplies: 7Last Post: 18-08-2018, 05:06 PM -
NEW MEMBER: Big hello from a total novice
By Edendale in forum New Member IntroductionsReplies: 1Last Post: 29-01-2018, 11:03 PM -
NEW MEMBER: Heres me - a Total Novice
By CrazeUK in forum New Member IntroductionsReplies: 1Last Post: 14-03-2017, 03:47 AM -
Total novice seeks advice on stepper motor drivers
By R.Andersen in forum Motor Drivers & ControllersReplies: 1Last Post: 25-01-2012, 11:34 AM -
Total novice and lost
By sfallan in forum Machine DiscussionReplies: 48Last Post: 10-09-2010, 10:35 AM
