    Hi chaps. I am trying to wire up the CSMIO/IP-M board. and I am not getting very far. I cant read the wiring diagram on the net as its to small and when I try to print it larger it just looks like a lot of dots. so these are my questions
    1. do I need the input terminal block connected if I am using the ethernet cable ???
    2. on the outlet side terminal block how do I know which number on the block goes to which input on the stepper motor driver.
    3.do I need to use the Estop unit at all, can I loop it for testing on the worktop. is so how. I don't understand how this connects to the CSMIO unit,
    4. from what I have read I need to add a plugin to mach3 to make the CSMIO work. is this correct and how do I do that.
    sorry for all the questions.Click image for larger version.
ID:	25127Click image for larger version.
ID:	25128Click image for larger version.
Name:	ss board.jpg
ID:	25129Click image for larger version.
Name:	stepper driver.jpg
    The manual should answer all of your questions.
    https://en.cs-lab.eu/wp-content/uplo...oipm_en_v2.pdf
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  1. FOR SALE: Cs labs csmio ip-s
    Last Post: 22-07-2018, 08:45 PM
  2. csmio/ip-m z probe
    By charlieuk in forum CS-Lab (CSMIO)
    Last Post: 16-09-2017, 09:49 AM
  3. CSMIO/IP-M with baldor smartstep/3
    By Benja in forum Denford Mills
    Last Post: 03-07-2017, 12:44 PM
  4. CSMIO-IP A &a Chinese spindle
    By D-man in forum CS-Lab (CSMIO)
    Last Post: 06-02-2017, 03:44 PM
  5. Mach3 oem buttons with CSMIO-IP/S
    By Web Goblin in forum Artsoft Mach (3 & 4)
    Last Post: 07-11-2016, 07:14 AM
