I'm intending to add a layer of foil-faced Tecsound damping sheet inside my gantry extrusion, I've found it very effective in the past on metal enclosures. I may also try some expanding polyurethane foam, either on it's own or in conjunction with the Tecsound: just need a bit of time to experiment!.
The Following User Says Thank You to Voicecoil For This Useful Post:
24-11-2018 #2
24-11-2018 #3
Tecsound is good stuff, but to get the best of it DO face the side that's not stuck to the extrusion with some metal foil or thin metal sheet, this gives the "constrained layer" effect where bending of the substrate is translated into shearing of the Tecsound which is MUCH more effective than just bending/wobbling it. 100u foil tape seems to work pretty well (I used it with good effect to quieten down my awesome but quite noisy Subaru STi) but if you can find something thicker it would improve further.
BUILD LOG: Comments sought on new build: A CNC Router for RC Gliders and Planes
By njhussey in forum DIY Router Build LogsReplies: 817Last Post: 13-04-2020, 05:03 PM -
BUILD LOG: Build Log: 4'x4' Moving Gantry CNC Router
By GeorgeW21 in forum DIY Router Build LogsReplies: 14Last Post: 20-01-2019, 09:33 AM -
BUILD LOG: Eyeballs and comments sought for noob build
By danilius in forum DIY Router Build LogsReplies: 20Last Post: 02-04-2017, 11:40 PM -
Using a metal cutting burr with a router...?
By noyloj in forum Metalwork DiscussionReplies: 34Last Post: 10-01-2017, 12:44 AM -
BUILD LOG: First Build-Steel Gantry CNC - Comments on design wanted
By olaff in forum DIY Router Build LogsReplies: 13Last Post: 06-12-2015, 08:34 PM
