    I'm trying to work out exactly what the purpose of this valve assembly is.
    It was attached to the body of a spindle on a gantry cnc router.
    Clearly it is supposed to direct either air or coolant to the cutter, BUT, it has two pipe connections, one with a valve (actually it's a Meter-in speed controller valve) and one without.
    The pipe connector on the right of the block, without the valve, has a pipe running back to a electricly operated valve which has another length of pipe from it which is just floating about free.
    Obviously I can connect the electric solenoid valve to compressed air and have an air jet blowing onto the cutter, but whats the purpose of the valve on the cutter end?
    I wondered if it would allow coolant to be drawn up via another pipe to give a mist?
    I'm not sure the meter-in speed controller valve is meant to have liquid in it.
    I can just bin this assembly and run a flood coolant with a small submersible pump instead. It might be useful to keep as an air blast for use on wood, mdf etc?
Name:	20181129_171320 (Medium).jpg
  1. Triac - old version, retro fitted servos
    By Benja in forum Classified Ads, Buy, Sell & Swap
    Last Post: 23-02-2018, 12:28 PM
  2. Replies: 13
    Last Post: 12-05-2017, 09:10 AM
  3. Replies: 4
  4. Anyone making fitted kitchens?
    By Chas in forum Woodwork Discussion
    Last Post: 31-01-2013, 05:29 PM
  5. Custom Vacuum Table 'Hold Down' System - piping/valve advice
    By FlightCaseCo in forum Machine Discussion
    Last Post: 16-01-2012, 06:56 PM
