What pressure did you use?
If it is a venturi, and you used too high a pressure, the restriction of the outlet would cause it to blow air out the coolant inlet, instead of creating a vacuum.
Most of these things are designed to run around 1-3bar, so start with a pressure regulator fully wound off, then gradually increase the pressure.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
Triac - old version, retro fitted servos
By Benja in forum Classified Ads, Buy, Sell & SwapReplies: 2Last Post: 23-02-2018, 12:28 PM -
555 timer circuit to control 12v solenoid air valve (for intermittent bursts of air).
By Wal in forum General ElectronicsReplies: 13Last Post: 12-05-2017, 09:10 AM -
Denford router - Brushed router too brushless spindle - Help and advice please
By Tom B in forum Brushless Spindles & MotorsReplies: 4Last Post: 16-05-2016, 09:13 AM -
Anyone making fitted kitchens?
By Chas in forum Woodwork DiscussionReplies: 12Last Post: 31-01-2013, 05:29 PM -
Custom Vacuum Table 'Hold Down' System - piping/valve advice
By FlightCaseCo in forum Machine DiscussionReplies: 4Last Post: 16-01-2012, 06:56 PM
