Thread: Machine Down!!
    Lives in East Lothian, United Kingdom. Last Activity: 3 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    That should be relatively easy to convert to a different controller.
    Regarding the VFD, from memory, DCM is normally a 0V which I would expected to connect to pin 14. However you really need to find a manual for the VFD. If you were to go for a CNCdrive UC controller, I'd probably suggest the UC400 along with a suitable breakout board.
    You'll most likely need to add an additional power supply to power the controller and breakout board.
    Hi m_c
    Thanks for replying to my post, after some research I think you are correct the DCM pin looks to have been connected to pin 14. I found the following video on Youtube
    I have also linked a copy of the user manual for the VFD, if you get a chance could you confirm?
    I've had a look at the UC400, this looks to be an ideal solution and also future proofs the machine, do you have any recommendations on breakout boards and PSU's I've had a look and theres quite a lot to choose from? CNCDrives BOB's don't really explain the connections very well, I'm also not sure how the VFD connects to their BOB's? I can't seem to see PSU's for sale on CNCDrive?
    Thanks again.
    Regards
    Dougie
    I'd double check with a multimeter, but I'm pretty sure the DCM should go to 0V (it's been a while since I've had to wire up a VFD!). Hopefully somebody else will confirm.
    BOB wise, I'd guess the usual cheap generic 5-axis Chinese ones available on eBay is as good as any for a basic machine, as they include the needed circuitry to get a 0-10V analogue output for speed control. I'm not entirely sure if there is any difference between the green and blue ones...
    PSU wise, I personally prefer DIN rail mounted supplies, but there are lots of options. I'd think you'll only need a 12V supply, as the UC400 takes 12-24V, and everything on the basic BOBs uses 12V (plus I think you need 5V via the USB for powering the step/dir outputs).
    Typically, S1 and DCM would go to a relay, with the relay closing the circuit between them.
    Not sure what they were doing with S3-S5?
    My recommendation would be the UC300ETH with a UB-1 breakout board from CNC Room, but it's not cheap. Very easy to wire up, though.
    https://www.cncroom.com/interface-cards/uc300eth-ub1
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    Hi all,
    First of all thanks to all who have replied to my post your help is greatly appreciated.
    I am about to order the UC400ETH along with the UCCNC software, however as I will also need to upgrade the breakout board I have found this to be a bit of a headache due to the options available. I have found the following three all on various websites can anyone recommend a BOB that will be compatible, and what the difference is between a £10 board to a £50 board?
    CNCDrive
    CNC4You
    eBay
    I have also found on Stoney CNC using the HDBB2 board (see attached), as they are UK based presumably they would arrive before Christmas, Ideally I would like to get the machine up and running again during the holidays.
    Thanks again
    Dougie
Name:	Screen Shot 2018-12-09 at 19.08.36.png
    The UCBB board will NOT work with the UC400ETH. It also doesn't have analog speed control, which you probably need for the spindle.
    A $10 breakout board is the cheapest you can get from China.
    In some cases, a $50 breakout board is the same board, but imported, sold and supported by a reseller.
    In other cases, it will have more features.
    Gerry
    Hi all,
    Thanks for everyones previous replies, I never managed to get my router upgraded as per my previous posts as I managed to grab a hold of an old XP pc which got me up and running again with NCStudio.
    Sadly this has now given up the ghost (I think the dampness in my garage is killing the pc's) and I'm now back to where I was before Christmas with a router that is now not working. I have been saving up my pennies for this day to come and have now decided its time to bite the bullet.
    I have spotted the following on CNCDrive which is on special offer with a UCCNC licence included:
    http://www.shop.cncdrive.com/index.php?productID=965
    Can someone advise if this would be suitable for my machine?
    I have a spare Windows 10 pc lying around which has not too bad a spec, other than a new PSU for the controller, what would I require to get my machine back up and running?
    Has anyone any knowledge of this controller, is it fairly easy to setup and get running?
    If anyone has any other suggestions I am open to ideas, obviously price dependant.
    Thanks again
  1. Newbie Machine Build Log (Fancy Machine)
    By Fancy in forum Gantry/Router Machines & Building
    Last Post: 18-09-2018, 06:15 PM
  2. Replies: 10
    Last Post: 14-02-2018, 12:45 AM
  3. Replies: 0
  4. Replies: 0
