Hi all,
I'm just in the power supply sizing phase of my CNC build.
My specs:
4x DM542 drivers at a max of 50V each.
4x 4.2A/3.8mH/425oz-in Nema 23 steppers.
I've calculated that:
4x 4.2A gives me 16.8A current draw. Make it 70% of that gives me around 12A requirement.
Max voltage of drivers is 50V, so to get an input of around 42V, I'd need a transformer with secondary of about 30V (or 2x15V x 1.414 for regulation and filtering capacitance).
12Ax30V is 480VA, so If I go with 625VA to be safe, would that be ok?
Neal
03-12-2018 #2
12A*30V = 360VA
With toroidal transformer even 60% of the rated current is safe. This is giving you 10A*30V = 300VA.
In my opinion anything above 300VA is ok. Using large smoothing capacitor(s).
03-12-2018 #3
WOW that's embarrassing. I'm putting that mistake down to lack of sleep. Thanks. I'll go for a 500VA then as they aren't too expensive. As for smoothing caps, what is the formula for calculating their size?
I think I read somewhere that its 80000xcurrent/voltage?
So 80000*12A/30V......about 32000uF?
03-12-2018 #4
I don't know how to calculate. If I remember well, I have put two capacitors with 10000uF @63V each, and I haven't had any problem so far.
04-12-2018 #5
04-12-2018 #6
I'm glad I could help.
There's one downside with a big toroid. When it's being energised it sucks a lot of power. You could see the lights dimming for a fraction of a second and even your circuit breaker tripping. Large transformers usually have a soft start circuit. If your mains power is strong enough and the circuit breaker is type C, you will be fine though.
Which power supply to use
By Palletlad in forum General ElectronicsReplies: 20Last Post: 13-04-2018, 05:34 PM -
Power Supply
By Ricky Burton in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 25-03-2018, 10:38 PM -
FOR SALE: power supply
By Web Goblin in forum Items For SaleReplies: 0Last Post: 14-09-2014, 03:19 PM -
Minimal-cost Power Supply Strategy - Repurpose Laptop Power Supplies
By LoveLearn in forum General ElectronicsReplies: 0Last Post: 25-01-2012, 09:29 PM -
FOR SALE: 50V 20A Power supply
By Jimmybristol in forum Items For SaleReplies: 8Last Post: 30-05-2011, 11:01 PM
