13-12-2018 #7
Thank you, Routerdriver. The software is equally bothersome, as I understand this area can vary in expense and efficiency almost as much as the machine it drives. So I will be devoting a lot of attention in this area.
Work area, noise and mess are already well covered! We produce over three tonnes of sawdust every year and the factory is ear-defender central! Most of the work surfaces are dedicated, so I will build a bespoke work area for the CNC once we decide which type and what its particular requirements are.
BUILD LOG: New build with recycled parts on a ridiculous budget 120cm*60cm work area
By Desertboy in forum DIY Router Build LogsReplies: 624Last Post: 08-01-2026, 11:55 AM -
WANTED: SCHOOL DT Dept needs basic Denford or Roland router running 2D Design
By scoutcentre in forum Items WantedReplies: 1Last Post: 31-01-2018, 09:53 PM -
Mach 3 - Set up my CNC router and a basic lesson. I'll pay! Based Sheffield U.K
By cabinetman17 in forum Artsoft Mach (3 & 4)Replies: 5Last Post: 04-07-2017, 08:27 AM -
Entry level router for plywood furniture?
By paulc in forum Machine DiscussionReplies: 2Last Post: 19-05-2017, 08:06 PM -
machine 1.5m x 3m to cut birch ply 18mm 4x8 sheets
By ckleanth in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 20-04-2016, 01:50 PM
