Thread: Hi from eastern France !
09-12-2018 #4
Thanks for the advice, for the router it's not so much the Z travel itself that needs to be long but the Z clearance, basically I need to able to machine at most about 75 mm deep (hence travel of 150 at least for tool clearance) but on parts that can be 100mm to 450mm thick (where the top gets machined) but I do not need to be able to do both at the same time, so a solution might be to have an adjustable table height or simply a high gantry style router and use table risers for the low parts to bring them up to the Z axis..
Definitely still a work in progress...
I'll probably start with the grinder though, kind of more urgent for me
Anyways I'm going to start on the grinder first because that's the one that is more urgent to my needs
NEW MEMBER: Hello from France
By racerbear02 in forum New Member IntroductionsReplies: 0Last Post: 23-10-2014, 09:19 PM -
By Noname in forum New Member IntroductionsReplies: 1Last Post: 23-12-2010, 05:10 PM -
NEW MEMBER: Hi from France
By pyromane0018 in forum New Member IntroductionsReplies: 1Last Post: 12-12-2010, 09:27 PM -
By copeau in forum New Member IntroductionsReplies: 1Last Post: 08-12-2010, 01:37 PM -
NEW MEMBER: Greetings from......France
By la_coterie in forum New Member IntroductionsReplies: 1Last Post: 23-06-2008, 12:46 PM
