    https://youtu.be/XpTfvvUelek
    Tired of fighting against bubbles, no vacuum chamber ?
    Look at 9:12, i can't understand...
    Best regards
    Quote Originally Posted by aprex View Post
    Best regards
    Can't open the video because of lack of internet. But I know that you can use a flame spray to remove all the bubbles. Also heat gun works. But don't heat up the epoxy too much. As this would result in an overreaction and epoxy starts to cook.
    Sent from my MI 6X using Tapatalk
    Ger21's Avatar
    Lives in Detroit, United States. Last Activity: 3 Weeks Ago Has been a member for 9-10 years. Has a total post count of 651. Received thanks 90 times, giving thanks to others 0 times. Referred 1 members to the community.
    alcohol?
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    Heat gun was inefficient for me against a sort of surface foam.
    I also have to deal with ungluing caused by thermal expansion of the frame...
    Ok, the answer is here:
    https://youtu.be/2PKn-59pHNM
    Acetone or denatured alcohol
    I will try this for the gantry.
    Honestly try the flaming thing. Works really good. Did it several times
    I noticed that after spraying with acetone, the epoxy started to flow from the edges. Is it possible that the acetone is influencing the consistency/quality of the epoxy?
    Yes that's in my eyes a problem why I would prefer the torch. The addition of Aceton rapidly decrease the strength.
    Here you go from Westsystem.
    https://epoxyworks.com/index.php/thi...-system-epoxy/
    Ger21's Avatar
    You really need to watch the video. You're not really adding acetone to the epoxy. It's just getting the bubbles out.
    Gerry
    I did. But I would still say you are mixing it a bit with Aceton. Sure most of it will evaporate. But I have some friends doing epoxy tables. But just art purpose. And they all use blow torches. Also that guy in the video uses light from above not from the side which is the proper way to see uncertainties. At least when building surfboards :-) with epoxy. I don't say it's really bad but if there's a proper way which is proposed by the producer I would go that way. I own a vacuum chamber so I don't have to deal with it any way :-).
  1. Self levelling epoxy resin
    By flanagaj in forum Gantry/Router Machines & Building
    Last Post: 21-11-2020, 01:47 AM
  2. Use of epoxy for levelling
    By Neale in forum Gantry/Router Machines & Building
    Last Post: 25-08-2019, 04:21 PM
  3. is Epoxy levelling just for steel ?
    By Hulksmash in forum General Discussion
    Last Post: 20-07-2018, 07:42 AM
  4. Self levelling epoxy
    By samsagaz in forum Gantry/Router Machines & Building
    Last Post: 07-05-2016, 12:40 AM
  5. is it possible to do a diy help spray machine?
    By reefy86 in forum Machine Discussion
    Last Post: 18-01-2016, 11:38 AM
