    Why don't you just epoxy level both axis and you are done? Here is a good example and there's a lot more information about it on this forum.
    Epoxy yes.
    But... a bolted frame. Is it to be moved a lot?
    So is it rigid and tight fit so to be able to take apart and together exactly the same ?
    If there is any room for error .. it is no use, not really
    Maybe a dowelpin system might work to get the same fit every time.
    Btw my welded steel frame had +/- 1.5mm @ 1850mm distortion after welding.
    Warping and twisting in all directions.
    Needed about 7mm epoxy thickness to level out, and have at least 4mm at the high spots.
    Grtz Bert.
    I cannot see why and how would you disassemble and/or move a 4 meter long cnc. I see it bolted down on a thick concrete floor in its final position and then epoxy levelled.
    Grtz Bert, in your place I would have poured two layers of resin. For let's say a minimum 2% of resin curing shrinkage at your 3 mm thickness difference you've got a 0.06 mm final level error. It is not a lot but it could be avoided.
    Hi paulus.v
    yes. i agree.. 0.06 .. it might need another pour..
    I hope i can work at that precision level and size any time soon and notice problems in my build.
    I am gonna do a laser beam check in a few weeks..
    On topic.
    If it is at its final position and all diagonals and braces are welded ... go for it. Epoxy level.
    Grtz.. Bert.
  1. Mystery Find what is it.??
    By JAZZCNC in forum General Discussion
    Last Post: 26-06-2016, 01:13 AM
  2. NEW MEMBER: Time To Find Out About CNC
    By Journeyman in forum New Member Introductions
    Last Post: 10-02-2016, 12:24 PM
  3. PC cannot find CD ROM ?
    By manofgresley in forum Computer Hardware
    Last Post: 06-12-2013, 02:35 PM
  4. How to find first job as CNC operator ?
    By malzyk in forum Opportunities Available & Sought
    Last Post: 07-09-2013, 04:21 PM
  5. Trying to find a kit or plans to build.
    By don_jarr in forum Gantry/Router Machines & Building
    Last Post: 16-06-2011, 04:28 PM
