    If you had a square and a scriber you could mark it out accurately and cut it with a hacksaw then finish with a file.
    Everyone seems to forget completely about the importance of good bench work once they've seen a machine ;-)
    A sliding table saw with a very sharp blade will also work.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  3. The Following User Says Thank You to Ger21 For This Useful Post:
    I have a piece of my late father-in-laws work from his pre-war Army training in the Signals. It is a test piece, a steel plate with a 1" square hole and in the hole is a friction fit 1" steel square. You can put that inner square into the hole in any rotation or turn and the fit is the same - perfect. All this was done with a drill, a file and a micrometer. My bench work is crude and impatient by comparison.
  5. The Following 2 Users Say Thank You to cropwell For This Useful Post:
  6. #4
    The way to do it is go to butchers with a small precision square in the pocket. And politely check their machine before cutting. Once they see the precision square, they will understand you mean it square... I have been laughed at but at the end i achieved mine, in terms of precision...
    Better to know you as the Precision Loco. In Spain we say : El que no llora no mama, meaning if you don't cry there is no a tit for you
    Lives in Marple Stockport, United Kingdom. Last Activity: 20 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Or you could say: yo solo habla catato
  8. #6
    I read your comments and I've decided to go to a machine shop with a mill to trim the ends. Hoping to get away with trimming 2mm total. Also I am gonna keep you posted on my build log. Thanks for the help guys.
  1. BUILD LOG: Made of aluminum, Made for aluminum: Would love design critique!
    By gamingan in forum DIY Router Build Logs
    Last Post: 27-06-2017, 11:33 AM
  2. 8020 T Slot Aluminum Extrusion
    By Fivetide in forum Marketplace Discussion
    Last Post: 26-11-2016, 12:37 AM
  3. Aluminum finish
    By Boyan Silyavski in forum Metal Finishing Techniques
    Last Post: 07-09-2014, 07:32 PM
  4. NEW MEMBER: where to buy aluminum extrusion
    By troyboy1 in forum New Member Introductions
    Last Post: 21-07-2014, 01:52 PM
  5. tool for aluminum on uk
    By edgas10 in forum Tool & Tooling Technology
    Last Post: 26-04-2011, 11:23 AM
