  1. Hello everyone
    i am new here and i live in holland.
    i did wotk for 32 years with cnc turning and milling machines and now i am working as a tech teachers at a school.
    for my hobby i want to build me a router in the sis 1000x800 mm.
    i have some ideas but nw is my questionnhere,what to built.
    Extrude alloy or steel.
    both is for me no problem ally is easier than steel
    like to know from you people about this
    greatimgs from holland
    Frank
  2. Hello Frank,
    I have built a 1000x800 CNC router. I can share my design and comment on my experience with it.
    What sort of work would you like to do on your router. Knowing the materials you wish to cut and the style of jobs will help me and others to help guide you.
    Simon
    Sent from my SM-G925F using Tapatalk
  3. Click image for larger version.
    Hello
    the materials will only be alloy,to make parts for quarterscale cars.
    The firts picture are the cars i made ten years ago
    i did have a machine ten years ago and did sell it.
    now i want to build a new machine and the size will be 1000x800.
    i did make some big scale cars and have some more ideas to make new ones.
    i do want to male a router for these cars and want to know which is better a steel frame or alloy extruded
    i allready have made a z-axle
    i also want to make it low budget.
    i used china linear rails and china closed loop steppers and drivers.
    i do believe these parts will do for what i want to use the router for.
    The old machine was a bad design and i did make the full cars on the first picture with it
    i do have cnc experience for 32 year as miller and turning.
    i am good in solidworks and solidcam amd did get the most certificats for it.
    i did switch career this year and i do teach kids in the age 13 /14 years at school in the technicals skills.
    sorry for the dutch english
    grt frank
  4. Hi Frank,
    They are very interesting cars, I'd like to look at the design in more detail sometime.
    I too use SolidWorks on a daily basis. I use Fusion 360 for CAM. Used to use HSMWorks inside SW.
    I would suggest not to use an aluminium frame if you are thinking of machining those aluminium parts. Not enough mass or rigidity especially over 1000mm travel.
    What's the travel on your X axis? Do have a spindle design in mind?
    Regards Simon
  5. x will be 1000 mm and y 800,z will be 100 to 140.
    i want to make anlower point in the frame for more z hight
    the spindle 80 mm hf,
  6. What is your email and what version of SolidWorks do you use. I'll send my design and I can explain what's good and bad about it. It might help with your design.
    Simon
  7. inuse Sw 2018 and my mail adres is [email protected]
  1. NEW MEMBER: Production grade CNC router Vs Homebuilt CNC router advice
    By SweetAs in forum New Member Introductions
    Last Post: 16-02-2019, 12:06 PM
  2. Replies: 4
  3. what router can i use with openbuild ox gantry router?
    By davejavu123 in forum OpenBuilds OX CNC Machine
    Last Post: 13-08-2015, 01:40 PM
  4. eBay: CNC Router - EXELCNC HD1013 - Heavy Duty CNC Router
    By Deuce_Coupe in forum Items On eBay UK
    Last Post: 16-07-2014, 11:46 AM
