    Many people would not use a floating end as said above, but many like me would use rigid both sides. So depends of what you do exactly and for what is meant exactly. Also if you dont say explicitly angular contact bearings, all chinese ball screw mounts come with simple bearings
    Really. I don't think that most people use rigid both ends, I would say at the most 5%. Also all Chinese ball screw mounts do not come with simple bearings as you put it. In fact Fred at BST will generally ask what type you want.
    It would be fair to say that for the Z axes on a small mill or router would almost never have a fixed bearing on the other end
    My second machine did not have a machined floating end on the X axis ballscrews and I had some 16mm ID bearings that were a perfect fit so used those. The machine ran well for many years and both mk3 and the current machine are like that. So it can be done and works ok but you wouldn’t see it on a commercial machine.
    On the unsupported end question all my machines had supports even on Z but I couldn’t fit them on mk4 as they ran inside the side members of the Z axis. It works fine and I think up to 300 mm is OK unsupported. After that you need to think about the free end starting to whip at high speed.
    Not many machines (DIY) have double support but it should help with longer screws rotating at higher speeds. My mk4 effectively has something similar on the X axis to give tension.
    On my Chester conversion I though there may be a chance of whip at higher speeds for the X axis so I have mounted the screw between bearings in tension. Y is too short to worry about but I might do the same for Z as that's also quite long.
  1. Drag chain size and length needed for 6040 CNC
    By nirmal in forum Chinese Machines
    Last Post: 02-05-2016, 11:24 AM
  2. FOR SALE: YG1 Standard Length Two Flute Slot Drills - 8 new cutters
    By Solihull1 in forum Items For Sale
    Last Post: 26-02-2015, 03:39 PM
  3. Relationship between Guide rail length and ballscrew length
    By CharlieRam in forum Rails, Guideways & Bearings
    Last Post: 11-07-2014, 11:37 PM
  4. FOR SALE: Any one wishing to buy a CNC length stop bench can make me a offer
    By suesi34e in forum Items For Sale
    Last Post: 07-05-2014, 10:20 PM
  5. Ideas sought to deburr a 5mm length of 5mm dia steel!
    Last Post: 22-03-2010, 08:48 PM
