    Wal's Avatar
    Lives in Stockport, United Kingdom. Last Activity: 15-12-2024 Has been a member for 9-10 years. Has a total post count of 491. Received thanks 71 times, giving thanks to others 29 times.
    Hello and welcome.
    If you have the time and the inclination, then definitely build your own..! Have a look at the builds on here and start asking questions / thinking about your own design. Off the top of my head, for what you're wanting to achieve a gantry style router (not dissimilar to mine) using 20mm alu plates and extrusions should serve you well. Go for a twin ball-screw on the axis which drives the gantry (usually the Y) - this introduces a bit of complexity regarding set-up later on, but means that you can dial out any racking/skew. I'll be up-grading mine to a twin-screw on the Y in the not too distant...
    Of course, gantry style machines at this size aren't going to be anywhere near as robust as a smaller fixed gantry style machine, but they're OK and will probably be fine for what you're going to be doing (unless you're trying to make hydraulic components for aerospace, which I doubt :) )
    Don't buy anything until you're equipped with a grunt approved plan, especially electronics.
    It's a great journey, you'll learn a lot (if you listen to the guys on here that know what they're talking about..!) and you'll forever have something to occupy you in your spare time.
    Wal.
    Hello and welcome.
    Thank you for the tips the kind words!
    I had a look at your build, and I must say, that machine looks amazing. By looking through that guide, one of the most basic questions I had, was: how did much it cost in the end (If you don't mind me asking, that is)? I am collecting ideas from various build guides, but what still eludes me, is how to effectively plan and dimension the machine in terms of cost. My budget is the biggest limiting factor for me, after all...
    Another question would be, if building a machine like that would be possible without access to a small mill in the first place? From those big plates, to the motor holders and even small brackets for the drag chain, you milled a lot of the pieces. Are there alternatives to that, or would I have to get them made by a third party?
    Finally, are there any examples for things you already made on that router?
    Of course, there are other questions, like how to drive the dual ballscrew, how to even mount the ballscrew, etc. But for those I will have to take a deeper, more in depth look, on the topics first. I would, however, take any recommendations for which build logs to look at (there are 14 pages after all!).
    Wal's Avatar
    Cost wise - Hmm... it's difficult to say, as there are probably loads of bits and pieces that I bought and have forgotten about..! But to give you an idea - my HiWin rails and bearing-blocks, ball-screws and bearings/housings came to US$850 including freight (US$200). I paid around UKŁ200 for my aluminium stock and the aluminium extrusion came to UKŁ200. The spindle and VFD will cost you somewhere around UKŁ250. Then you've got pulleys and belts (or direct drive motor mounts), e-chain, power supplies, drivers, motion control boards, a housing to, well, house all the electrics, a PC etc. You're easily looking at Ł2000...
    Yes - having access to metal working equipment and/or someone who can help you with some of that stuff (in my case CliveS - also of this forum) is going to be a massive help. But if you want a bit of inspiration as to what's achievable with some pretty basic gear then check out Joe's build:
    http://www.mycncuk.com/threads/4513-3-Axis-CNC-router
    Pretty cool. Here's his YT channel:
    https://www.youtube.com/user/joerharris/videos
    My very first build was a fixed gantry mini-mill type of thing - I had the frame fabricated and got a machine shop to drill the alu plates - in all honesty, with a bit of careful layout I could probably have drilled those myself..! My point is - there's often a clever way of simplifying something (and then getting the machine to make itself a better part once it's up and running..!)
    It would be a great help to you if you could find someone local that would show you around their home-built machine - at that moment a lot of stuff falls into place and starts making a bit more sense..!
    If you'd like to see some examples of what I've made with my two machines check out my instagram and tumblr links in my signature below.
    Wal.
  1. Searching for job
    By Junior in forum Opportunities Available & Sought
    Last Post: 30-08-2016, 07:00 PM
  2. Boxford 125 TCL Searching for machine problem
    By dragon in forum Boxford Lathes
    Last Post: 28-12-2014, 09:27 PM
  3. Replies: 0
  4. Boxford 125 TCL Searching for Machine Error
    Last Post: 01-03-2013, 07:57 PM
  5. NEW MEMBER: job searching
    By aaron in forum New Member Introductions
    Last Post: 17-02-2010, 02:35 PM
