    Hi Clive. Thanks!
    I didn’t change anything, coz frankly...I don’t understand it(willing to learn).
    I include all files in zip here. including untouched config. So anybody, or maybe even you can give it a try. It’s simple stepconf 2 axis lathe without feedback/inputs, so it will run without machine.
    I’ll appreciate any the help.
    Maros
    Attached Files Attached Files
    Quote Originally Posted by garulus View Post
    Hi Clive. Thanks!
    Maros
    Ok first. Have you actually got the lathe running under Lcnc? if not then start by getting the X and Z working first. then get to the tool changer later.
    Do you have homing working?
    Yes and no. I already have my mill up and running under linuxcnc, so I know what I’m doing with stepconfig. My lathe is just X Z steppers on the table + toolchanger. No home/limit yet. It is easier to test on PC without any inputs(homing manually in linuxcnc). All I need to know is how to implement this tool change component.
    Update:
    I copied file toolchanger.comp to my linuxcnc/configs/Lathe folder
    Then copied Header:
    # .ini file for axis - ATC set up as axis A angular
    [AXIS_3]
    to the end of my Lathe.ini file
    Then I copied:
    # example Hal linkages required:-
    setp stepgen.3.position-scale [AXIS_3]SCALE
    AND
    # loading the toolchange component in .hal file
    loadrt toolchanger
    addf toolchanger servo-thread
    In to my Lathe.hal file
    Then I run terinal in my configs directory to compile:
    sudo halcompile --install toolchanger.comp
    (sudo comp --install toolchanger.comp) don’t work!
    Still stuck Here when try to run linuxcnc
    /Lathe_Orac.hal:87: parameter or pin ‘stepgen.3.positio-scale’ not found
    When you use stepconfig it will overwrite any changes you have made. so it is best to not use it and hand edit the files after the first time setup.
    I have noticed that here:-
    [TRAJ]
    AXES = 3
    COORDINATES = X Z
    you might need to make it COORDINATES = X Z A
    Hi. I know that stepconfig it will overwrite any changes, but before I make final setup I need to know that I’ll be able to implement this toolchanger component. Keeping it simple for now.
    COORDINATES = X Z A(B,C) don’t work. Still same error message: /Lathe_Orac.hal:87: parameter or pin ‘stepgen.3.positio-scale’ not found
    It would be nice if anybody who understand linuxcnc will try to implement it, and share results/knowledge. It’s time to make good deed...to please north pole for upcoming x-mass 2019
    Well there are more people on the linuxcnc forum that do understand it. But are you sure that the error message that you have put up on here and the linuxcnc site is correct. /Lathe_Orac.hal:87: parameter or pin ‘stepgen.3.positio-scale’ not found
    Hopefully someone will try it and will help. And you don’t worry anymore. I appreciate your effort.
  1. WANTED: Boxford 190VMC toolholders, tool changer and manuals
    By davethesteam in forum Items Wanted
    Last Post: 06-11-2017, 11:29 AM
  2. WANTED: Boxford or Denford Lathe Auto Tool Changer
    By DagnW in forum Items Wanted
    Last Post: 27-03-2017, 10:45 PM
  3. Replies: 16
    Last Post: 27-03-2014, 10:26 PM
  4. WANTED: EMCO Lathe Tool Changer
    By Pete92 in forum Items Wanted
    Last Post: 01-10-2013, 10:27 AM
  5. Automatic tool changer
    By amen23 in forum Tool & Tooling Technology
    Last Post: 06-01-2009, 05:56 AM
