Thread: Where to buy router bits
The feeds and speeds are all just guides - you'll dial in your own settings based on the materials that you're cutting, spindle run-out (hopefully minimal), machine rigidity etc. I wouldn't worry about what a re-seller 'recommends' too much. Since you're starting out, grabbing yourself a bunch of cheap Chinese tools isn't that bad an idea - you're going to break a fair few of 'em..! The problem with the really cheap tooling is that the carbide isn't as high quality. They dull quickly and aren't as strong as what you'd be buying at the high end - having said that, I use pretty cheap tooling in a non-production hobbyist capacity and I'm perfectly happy with how they perform.
I buy from the following two sources here in the UK - not sure what the shipping situation would be out to Anguilla..!
APT
GBR
Yes - these suppliers are more oriented towards tools for cutting metal - however, I find that the single and twin fluted carbide tools that they sell perform very well in hardwood. You could also try these guys - but the money's a bit more serious now:
Wealden
If I were you, though - I'd grab a bunch of inexpensive cutters to mess about with first.
Wal.
The Following User Says Thank You to Wal For This Useful Post:
07-01-2019 #2
Oh sorry location is not Antigua ;-).
I guess it was randomly picked by me. I am from Germany so location shouldn't be an issue. I will then follow your advice. The APT shop seems to be a good middle way to thae really cheap ones from Bangood. I think I will buy a mix between both. So I can play with the ones from Bangood and then use APT ones.
Maybe an additional question. As my first task will be to mill my MDF spoilboard. Dimension will be 3,8m x 1,2m. The spoilboard bits especially have a huge variety in prices from 4- 250$. I think as I have a bigger table I should use a bit with at least an Inch diameter? Any recommendations which one is ok and doesn't break the bank?Last edited by feldah; 07-01-2019 at 03:44 AM.
07-01-2019 #3
You can change the location as that helps others when suggesting things.
I use one of these https://www.wealdentool.com/acatalog/Surface-Trim.html..Clive
07-01-2019 #4
+1 on this. A decent cutter for the money. Stay shallow with it and don't run it at 24K..!
09-01-2019 #5
For my spoilboard cleaning I bought this one. I've got a few other Arden tools as well. Not cheap but very good quality, made in Taiwan.
I bought before a similar one but cheap Chinese make and after surfacing a 20x10 cm piece of pinewood it went blunt. I think the inserts were just mild steel, not even HSS or something. Or they tried to bind the tungsten carbide particles with super glue? :)Last edited by paulus.v; 09-01-2019 at 03:03 PM. Reason: edited the ebay link
The Following User Says Thank You to paulus.v For This Useful Post:
09-01-2019 #6
Thank you guys. That's already a good selection. And good to see that I don't have to buy a 25$ bit as my first router bit. I started to get nervous that it was that expensive ;-)
09-01-2019 #7
I have edited the ebay link as the one I pointed has ended while writing the post. Not to be confused with the cheap Chinese yellow bits that ebay suggests! The Arden bits are sold only by one vendor, bestones2010
09-01-2019 #8
09-01-2019 #9
10-01-2019 #10
I don't know how long will they stay sharp. I didn't used them a lot and are all still sharp. I used the most a 1' dia round nose bit cutting about 500-700 meters in MDF and it is still very sharp.
I was also looking at CMT tools with replaceable inserts but I think the price is justified only if you are routing MDF as a business, which would mean cutting maybe 500 mtr per day or hour.
I think all tungsten carbide in tools is sintered. Mixed with cobalt and liquid sintered, where the cobalt melts and fills the space between the carbide particles. Most likely those Chinese inserts had no tungsten carbide in the composition, they looked more like cast iron, maybe had some iron carbide inside :)
best router bits ?
By totally useless in forum General DiscussionReplies: 7Last Post: 01-05-2015, 11:53 AM -
Router bits for use with Slate
By habibuzziwa in forum Tool & Tooling TechnologyReplies: 1Last Post: 30-06-2013, 06:12 PM -
3.175mm router bits
By ian stenson in forum Tool & Tooling TechnologyReplies: 2Last Post: 13-06-2013, 07:59 AM -
SWAP: 6mm Carbide CNC Router Bits for 3mm's
By Fivetide in forum Items For SwapReplies: 8Last Post: 04-12-2012, 04:47 PM -
CNC Router Bits
By ploughex in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 01-08-2010, 06:26 PM
