Thread: Where to buy router bits
Great explanation. Sadly I won't have prior information about the stiffness. But I know that I will use a 2.2kw Spindle which can handle 1/2" shanks.
My 300m comes because my table is 4 times longer(1,2m - 1m) x 4m. Because it is my first cnc I am building. I was expecting an uneven table with 3mm height difference. But that's just a guessed number. So with a 2" tool and 1mm cut depth I assumed 20 x 4m x 3 rounds -> 240m. But as you said you are going a few tenth of a milimeter it will even be more runs.
12-01-2019 #2
The Following User Says Thank You to paulus.v For This Useful Post:
best router bits ?
By totally useless in forum General DiscussionReplies: 7Last Post: 01-05-2015, 11:53 AM -
Router bits for use with Slate
By habibuzziwa in forum Tool & Tooling TechnologyReplies: 1Last Post: 30-06-2013, 06:12 PM -
3.175mm router bits
By ian stenson in forum Tool & Tooling TechnologyReplies: 2Last Post: 13-06-2013, 07:59 AM -
SWAP: 6mm Carbide CNC Router Bits for 3mm's
By Fivetide in forum Items For SwapReplies: 8Last Post: 04-12-2012, 04:47 PM -
CNC Router Bits
By ploughex in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 01-08-2010, 06:26 PM
