    GH-1440A ? You could always ask Warco for their advice. Is the problem that you have moved the lathe out of the 3 phase environment ?
    Yes the Lathe has been moved from a 3 Phase environment I didn't know that the Lathe came from Warco ? I thought that they were from a place called Toolco.
    Lives in East Lothian, United Kingdom. Last Activity: 6 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    It's not specifically a Warco model. Like lots of Chinese built machines, it'll be produced by a factory who will stick whatever logo you want on it, and give you a few different specification variations. Plus as it uses a pretty conventional naming convention (Gear Head 14" swing 40" between centres), it may of even came out of different factories, with some copies better than others (aka Sieg/Syil).
    A quick google for GH-1440A brings up Warco, ToolCo, ETS, and Acra currently supplying that model. I'm sure there will of been more suppliers over the years.
    I mentioned Warco as it is green with ali info plates - as you say Chinese, probably from the weiss.com.cn stable. I can see why you are going for a VFD as £800 for a rotary converter - OUCH !
    Cheers,
    Rob
    Cheers,
    Rob
    I'm pretty sure even Chester used to supply certain models in green, so I never mention makes unless it's clearly mentioned on the machine.
    Rotary phase converters are pricey. The step-up transformer and motor are the big cost. The rest of the bits for a basic rotary aren't that expensive. A few big capacitors, and either a time delay relay (or voltage sensitive relay if you want to get fancy) plus some wire and terminals are pretty cheap.
    I used to have a link to a website that provided kits, including the option for electronic capacitor switching, but I can't currently find it. I was always tempted to upgrade my rotary with it, to eliminate all the relay/contactor chattering mine does when I start the milling machine up.
    Hi again do you think that a Rotary phase converter would be better than a digital phase invertor the problem is that they are all so pricey to be able to run the dual speed motor.
    My guess is that the rotary converter would be more robust. The reason is that the two speed switching would mean, that to be safe with an electronic converter, would ALL have to be powered down before motor is reconfigured for the other speed, otherwise there could be a momentary open circuit or short to blow the output gates.
    Looked into the Rotary phase converter and this would be the best option for us because the set up will allow the use of dual speed motor and also the additional option to use other equipment at the same time if required. Just wondering if anyone has a Transwave rotary converter and if so is it for Sale? preferably a RT4 model.
  1. wiring V1000 VFD from a 2.2kw Chinese invertor
    By dek667 in forum Control Hardware & Systems
    Last Post: 10-08-2018, 10:03 AM
  2. What machine is required please
    By Arzo10 in forum Machine Discussion
    Last Post: 06-03-2016, 12:01 AM
  3. WANTED: Off-cut required.
    By Wal in forum Items Wanted
    Last Post: 14-12-2015, 11:09 PM
  4. Replies: 0
    Last Post: 08-07-2014, 03:11 PM
  5. NEW MEMBER: Help required
    By Vespa Mad in forum New Member Introductions
    Last Post: 24-06-2009, 02:06 PM
