Thread: Invertor required
11-01-2019 #22
All these VFD's will be rectifying the AC input to DC, and then doing stuff with that to make the 3 phase O/P. For low power (and low cost) you can use a capacitor/diode voltage doubler on the input to generate ~650V DC, alternatively for larger power you can use a switchmode Power factor Corrector (PFC) stage to do the same and also keep you legal for harmonic currents. This will need just one (or a few) small decent inductors, if the switching frequency is high it's quite possible to get 3 KW through a couple of cores maybe 35 or 40mm across, larger powers pro-rata, so you don't need massive transformers.
wiring V1000 VFD from a 2.2kw Chinese invertor
By dek667 in forum Control Hardware & SystemsReplies: 1Last Post: 10-08-2018, 10:03 AM -
What machine is required please
By Arzo10 in forum Machine DiscussionReplies: 19Last Post: 06-03-2016, 12:01 AM -
WANTED: Off-cut required.
By Wal in forum Items WantedReplies: 8Last Post: 14-12-2015, 11:09 PM -
Help required with desktop cnc build - cutting out the required plates
By alanb in forum OpenBuilds OX CNC MachineReplies: 0Last Post: 08-07-2014, 03:11 PM -
NEW MEMBER: Help required
By Vespa Mad in forum New Member IntroductionsReplies: 1Last Post: 24-06-2009, 02:06 PM
