Thread: Chinese Ballscrew nut play
So i bought 4 ball screws of different lengths. Two of them have play in them, and the other two are stiff and have a considerable amount of pre load they even don't rotate as easy while the others rotate freely. I never handled ball screws before, and i was wondering which of the following is considered normal behavior ? one nut if i give it a spin rotates +3 rotations and the other rotates 1 time and stops. Also what to do to fix the ball nut play ? I've read that i can Repack the ball nut with larger balls, if you find this as a suitable solution would you please point me to a seller on ebay preferably ?
10-01-2019 #2
Are the ballscrews new Chinese ones or used? Do the ballnuts have dust wipers at the ends? Only after removing them you can see how easy is the nut rotating. If you tighten too much the wipers on a Chinese ballnut, it won't rotate freely anymore but doesn't mean the balls are preloaded..
10-01-2019 #3
Yes they are new Chinese ones. I tightened the dust wipers and that eliminated all play in the nut. Before that it was moving you could say 0.5mm in all directions.
10-01-2019 #4
That's not how it works, you'll just wear your wipers out, the only way to adjust play in a single ball nut is to replace the balls with a slightly larger grade, when rebuilding alternate balls should be smaller than the required spec to allow free ball rotation and minimise friction and wear.
10-01-2019 #5
0.5 mm of play is a lot. maybe they put the wrong ball size in. Get in contact with the vendor, probably he will send you the correct size balls. But anyway you want to first to take off completely the wipers from the screw for troubleshooting, then eventually take out one ball or all and measure them, etc. Putting back the balls in a nut is not an easy task but doable, there are videos on youtube on how to do it easier.
When I bought my ballscrews I asked for a few spare balls and they gave them for free. First thing I did was to take out the ballnut and balls, check for missing balls and clean everything. Sometimes there is swarf inside left from machining and the nut is not rotating as it should be, sometimes a ball could be missing..
11-01-2019 #6
There should be about 0.05 mm play. The vendor has to match the balls to tune the free play / ease of rotation depending on the fit of that nut on that ballscrew.
Nominal ball size (for 1605 1610) is 1/8” of an inch (3.175mm) but they can be tuned up or down in something like 0.02 mm steps. Some vendors will then engrave this number on the ballnut(Fred at BST for example). So they may be marked +2 for 0.02mm oversized.
If anyone has links to these tuning sets I would be interested as one of my spare ones could be dialled in better. Seem to remember Lee had some ??
Play in my mount
By CrazeUK in forum Rails, Guideways & BearingsReplies: 11Last Post: 03-03-2017, 06:27 PM -
I need Ballscrew end machined....what do I tell the Chinese bloke doing the work?
By HankMcSpank in forum General DiscussionReplies: 10Last Post: 23-02-2017, 07:24 PM -
Thread cutting in chinese ballscrew
By noyloj in forum Metalwork DiscussionReplies: 19Last Post: 22-02-2017, 10:05 PM -
Anyone play World Of Tanks ?
By Fivetide in forum General DiscussionReplies: 15Last Post: 10-09-2012, 11:46 AM -
Should my Z axis have a little play in it?
By Philly in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 29-04-2011, 04:28 AM
