Thread: Chinese Ballscrew nut play
The sizes i found were 3.12, 3.14mm and 3.16mm and the ones that were packed in the screw were 3.10mm. i tried each by them selves @ 3.12mm there was wiggling so i increased the ball size the wiggle decreased but the at some points along the screw it got harder to turn then i tried alternating with 3.10 but no luck 3.12 & 3.10 wiggles & 3.14,3.16 with 3.10 wiggles and get harder to rotate at some points along the screw.
11-01-2019 #2
It sounds like you've got cheap rolled ballscrews, which as you've discovered, are not great for accuracy.
The only thing you could do (other than buy a new screw), is put the bigger balls in, and hope they wear/burnish in the tight spots on the screw, but you do risk damaging things if thing are too tight. If you do try this approach, I'd make sure things are kept very lubricated to help flush any debris out, until you are happy things have bedded in nicely.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
Play in my mount
By CrazeUK in forum Rails, Guideways & BearingsReplies: 11Last Post: 03-03-2017, 06:27 PM -
I need Ballscrew end machined....what do I tell the Chinese bloke doing the work?
By HankMcSpank in forum General DiscussionReplies: 10Last Post: 23-02-2017, 07:24 PM -
Thread cutting in chinese ballscrew
By noyloj in forum Metalwork DiscussionReplies: 19Last Post: 22-02-2017, 10:05 PM -
Anyone play World Of Tanks ?
By Fivetide in forum General DiscussionReplies: 15Last Post: 10-09-2012, 11:46 AM -
Should my Z axis have a little play in it?
By Philly in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 29-04-2011, 04:28 AM
