Hi all
Can anyone suggest a supplier for good removable double sided tape so I don't need to spend a fortune to test it?
The best I have found so far is off fleabay but I was hoping to get it for less than a fiver for 25mm wide x 25 metres.
Thanks in advance
Carl
16-01-2019 #2
LIDL have 3M double coated tape 50mm x 15M - I don't know how much it costs (£1.99 at a guess) as I just dropped it into the shopping trolley and left the Finance Officer (wife) to pay.
18-01-2019 #3
Hi a better way is to use single sided tape. Place tape on bed and on the base of the work. Then using two pack glue from screwfix place glue on the tape. This will hold the work and after marching just pull the tape off.
08-06-2019 #4
09-06-2019 #5
screwfix. 5.99 for 50mm x 25metres
09-06-2019 #6
[QUOTE=johngoodrich;108996]screwfix. 5.99 for 50mm x 25metres[/QUOTE
Thanks but I was looking for removeable tape, some of the permanent stuff you can't even get off the scissors used to cut it.
double sided fsw and isf
By freddi in forum Machine DiscussionReplies: 6Last Post: 01-12-2016, 02:54 PM -
Double sided tape
By racerbear02 in forum Woodwork DiscussionReplies: 1Last Post: 28-02-2015, 07:52 PM -
Double sided tape
By racerbear02 in forum Woodwork DiscussionReplies: 4Last Post: 22-12-2014, 03:36 PM -
Video of CNC machining a double sided part.
By Shinobiwan in forum Woodworking Project ShowcaseReplies: 26Last Post: 17-03-2013, 11:23 AM -
Double sided machining
By CraftyGeek in forum General DiscussionReplies: 7Last Post: 08-12-2009, 11:04 AM
