09-06-2019 #2
screwfix. 5.99 for 50mm x 25metres
09-06-2019 #3
[QUOTE=johngoodrich;108996]screwfix. 5.99 for 50mm x 25metres[/QUOTE
Thanks but I was looking for removeable tape, some of the permanent stuff you can't even get off the scissors used to cut it.
09-06-2019 #4
I use this all the time and haven't had any problems with it unless you cut in to it and it can wrap around the spindle
09-06-2019 #5
I'm mainly using it to hold down thin A3 polycarbonate sheets and as I'm cutting small parts from them I need almost 100% coverage. The only take I've found that I can easily get off the cut parts is the removable stuff. Just looking for a cheaper source.
10-06-2019 #6
You could stick painters tape to bed, stick painters tape to sheet and glue both tapes using the accelerated instant glue. That's how i have seen it done normally. Or if you use strong double tape, just oil a bit the surface using old rag, so it does not stick like crazy.
10-06-2019 #7
Personally, I would rather see the workpiece firmly stuck, than moving around whilst you are cutting. For acrylic, I use fabric embedded carpet tape on a sacrificial bed of plywood and get the piece off afterwards by sliding an artists palette knife underneath. The tape then either comes off the bed or the workpiece (sometimes both) and because of the fabric reinforcement, can be pulled off, with a little cleaning up any residues with low-odour white spirit.
double sided fsw and isf
By freddi in forum Machine DiscussionReplies: 6Last Post: 01-12-2016, 02:54 PM -
Double sided tape
By racerbear02 in forum Woodwork DiscussionReplies: 1Last Post: 28-02-2015, 07:52 PM -
Double sided tape
By racerbear02 in forum Woodwork DiscussionReplies: 4Last Post: 22-12-2014, 03:36 PM -
Video of CNC machining a double sided part.
By Shinobiwan in forum Woodworking Project ShowcaseReplies: 26Last Post: 17-03-2013, 11:23 AM -
Double sided machining
By CraftyGeek in forum General DiscussionReplies: 7Last Post: 08-12-2009, 11:04 AM
