Thread: Stepper motor ampage question
18-01-2019 #11
I suspected you really meant closed loop. Yes, they will offer more performance for a given size, and will recover more gracefully depending on settings (I forgot to mention, one big issue with using a stepper for a spindle, is if you do stall it, it will probably remain stalled until you stop/restart it).
If you want to run some comparisons, find the relevant speed/torque curves, then run the figures through the calc here - http://wentec.com/unipower/calculators/power_torque.asp
One thing I should of mentioned in my last post about DC/Induction motors, is the rated power is only at full rated speed. So if it's 200W at 4000RPM, it will only deliver 100W at 2000RPM.
With an AC motor and VFD, you do have the possibility of running the motor above it's rated speed, however you enter a power constant stage. I.e. if the motor produces 1Nm at it's rated speed of 1500RPM (works out to 160W), if you were to double it's speed to 3000RPM, you would only get 0.5Nm (which is still 160W)Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
How do I wire a stepper driver to a stepper motor?
By swood1 in forum Stepper & Servo MotorsReplies: 7Last Post: 21-09-2014, 05:40 PM -
No longer lurking, stepper motor question.
By simonparkes in forum Stepper & Servo MotorsReplies: 8Last Post: 26-03-2014, 11:52 AM -
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Stepper Motor Power Question
By boldford in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 17-07-2012, 09:40 AM -
common wire on stepper motor question
By progomez in forum Motor Drivers & ControllersReplies: 1Last Post: 27-10-2009, 11:56 PM
