Thread: Stepper motor ampage question
17-01-2019 #2
If you use a TB6600 stepper driver set to 4A
a stepper motor rated at 4.2 amps will run at the 4A set by the driver so there should be no problem
the motor torque will be reduced to 4/4.2 of the rated torque
having said that I would be inclined to use the TB6600HG so the stepper driver is not run at is limit
John
The Following User Says Thank You to john swift For This Useful Post:
How do I wire a stepper driver to a stepper motor?
By swood1 in forum Stepper & Servo MotorsReplies: 7Last Post: 21-09-2014, 05:40 PM -
No longer lurking, stepper motor question.
By simonparkes in forum Stepper & Servo MotorsReplies: 8Last Post: 26-03-2014, 11:52 AM -
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Stepper Motor Power Question
By boldford in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 17-07-2012, 09:40 AM -
common wire on stepper motor question
By progomez in forum Motor Drivers & ControllersReplies: 1Last Post: 27-10-2009, 11:56 PM
