    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    It depends what you mean by hybrid. Pretty much all stepper motors you buy now are technically hybrid motors (most square motors are hybrid), and they are far better than conventional (typically round) stepper motors.
    A quick search of eBay has thrown up the likes of this - https://www.ebay.co.uk/itm/200W-220V...e/253850778051
    And they also sell a 500W version with a basic speed controller - https://www.ebay.co.uk/itm/500W-220V...d/253982275690
    To give you some reference figures, using the speed torque curve of a leadshine nema 23 motor (http://leadshine.com/productdetail.a...S&model=57HS22 - one of the first motors I found that has the needed data), at 2000RPM depending on configuration/supply voltage it's only producing 0.4 to 0.7Nm, which works out at 80 to 150W of mechanical power. To get that relies on driving the motor at 68VDC. Drop the voltage, and the torque will drop of far quicker.
    At that point costs are verging in to the same as buying a small single phase motor, or even three phase and cheap VFD. A quick ebay search shows a 1/2HP 3 phase motor can be had for £62, and a suitable VFD for £45. It will likely cost you more than that to get a suitable 68VDC power supply and suitable stepper drive.
    The only thing with using a standard induction motor, is they are far larger than a similar power DC motor.
  2. The Following User Says Thank You to m_c For This Useful Post:
  3. #2
    m_c I ment closed loop stepper sorry
    - Closed-loop vector control technology ensures the high torque output, while ensuring that the motor does not lose step.
    - With overvoltage, overcurrent, tracking error or over-error, and other protection features.
    - Closed-loop driver can significantly improve the high-speed performance of the motor, increasing the effective torque of the motor by more than 30%; Effectively reduce the motor heating and motor vibration, the output current of the driver becomes larger or smaller as the load and speed increase or decrease; It can improve the processing speed and accuracy of the machine and reduce the energy consumption of the machine.
    Ralph Waldo Emerson
    I suspected you really meant closed loop. Yes, they will offer more performance for a given size, and will recover more gracefully depending on settings (I forgot to mention, one big issue with using a stepper for a spindle, is if you do stall it, it will probably remain stalled until you stop/restart it).
    If you want to run some comparisons, find the relevant speed/torque curves, then run the figures through the calc here - http://wentec.com/unipower/calculators/power_torque.asp
    One thing I should of mentioned in my last post about DC/Induction motors, is the rated power is only at full rated speed. So if it's 200W at 4000RPM, it will only deliver 100W at 2000RPM.
    With an AC motor and VFD, you do have the possibility of running the motor above it's rated speed, however you enter a power constant stage. I.e. if the motor produces 1Nm at it's rated speed of 1500RPM (works out to 160W), if you were to double it's speed to 3000RPM, you would only get 0.5Nm (which is still 160W)
  1. How do I wire a stepper driver to a stepper motor?
    By swood1 in forum Stepper & Servo Motors
    Last Post: 21-09-2014, 05:40 PM
  2. No longer lurking, stepper motor question.
    By simonparkes in forum Stepper & Servo Motors
    Last Post: 26-03-2014, 11:52 AM
  3. Replies: 1
  4. Stepper Motor Power Question
    By boldford in forum Gantry/Router Machines & Building
    Last Post: 17-07-2012, 09:40 AM
  5. common wire on stepper motor question
    By progomez in forum Motor Drivers & Controllers
    Last Post: 27-10-2009, 11:56 PM
